Use a PSU calculator to find out. Just google it.
If you need help on used parts, contact me. I'm an used enthusiast.
Open the spoiler to see some cool stuff!
My old/new tech Collection!
CPUs (11)
Intel Pentium III @ 733Mhz (Oldest of the Bunch)
Intel Pentium 4 @ 2.8Ghz (2002)
Intel Pentium 4 @ 3.0Ghz (2003)
AMD Sempron 64 2800+ @ 1.6Ghz (2004, Aug)
AMD Athlon 64 3500+ @ 2.2Ghz (2004, Jun)
2X Intel Xeon X5355 @ 2.66Ghz (2006, Q4)
Intel Pentium E2140 @ 1.6Ghz (2007, Q2)
Intel Xeon E5630 @ 2.53Ghz (2010, Q1)
Intel Core2 Duo E8400 @ 3Ghz (2008, Q1) (In use, @ 3.61Ghz)
Intel Pentium E6500 @ 2.93Ghz (2008, Q1)
GPUs (6)
Palit GeForce 6800 GS (Should be working, AGP 8X)
Club 3D GTS 450 (Working, PCI-e 16x)
Sapphire Radeon X800GTO (Working, PCI-e 16x)
Nvidia GeForce 4 (Last time worked, AGP 4X)
Nvidia GeForce FX (No idea, AGP 4X)
Gigabyte Radeon HD 7970 OC (Semi-dead, PCI-e 16x)
Ram (1)
No idea of the brand or Socket (Whopping 16 Mb memory)
Cables (1)
CrossFire X Cable
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224701
Just now, Max_Settings said:
He can't because Vega is not out
But very soon right @LinusTech or it's under NDA for the release date?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224713
look at the power requirement for the vega then, if you can't then look at a picture of the vega where the connectors are connected and calculate it on your own.
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224714
Leaks say it's 400W so he can't use a 430W PSU
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224718
Ohh yea its surely 400W something, 2 8-pin connectors on it... that's already about 300W
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224725
Just now, CUDA_Cores said:
That depends. Is it a 430w seasonic, or a 430w diablotek?
EDIT: i'm a dumbass who doesn't read, you should be okay. But this is really a question for our forums PSU guy @STRMfrmXMN.
How is he ok? He wants to use a 430W PSU with a card that has a 400W TDP. So unless a R5 1600 is magically a 30W CPU he's not fine.
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224746
maxing out a PSU, WTF. Think of the constant shutdowns.
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224753
1 minute ago, Skilaruh said:
From the leaks I saw it was 300. If it is 300 is that okay
The 300W is just because of the 2 8pins. If the card draws any power through the PCI-E slot it's more than 300W. And your CPU is 95W. You are cutting it way to close if it does work.
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224771
I wouldn't use the 430W EVGA PSU in a build with anything over a 1050 TI in terms of heat output. That PSU isn't very good and most certainly should not be paired with a GPU that will have dual 8-pins on it.
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10224776
It would, but I would strongly recommend upgrading.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/815029-will-a-430psu-be-enough/#findComment-10226050
