So I'm going to be building my first PC soon, I've been binge watching LTT to make sure I know what I'm doing and what to buy but the one question I still have is about my thermal paste. I'm going to be using a Corsair H100i V2 AiO liquid cooler which has pre-applied thermal paste, should I use that paste or spend the extra $5-$10 to get some of my own and just clean the pre-applied stuff off?
https://linustechtips.com/topic/812253-thermal-paste-advice/
Use the pre applied stuff.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/812253-thermal-paste-advice/#findComment-10193834
Get MX-4, you will need more paste in the future anyway.
https://linustechtips.com/topic/812253-thermal-paste-advice/#findComment-10193839
The pre-applied and in box thermal compound from major CPU cooler makers are generally pretty good.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/812253-thermal-paste-advice/#findComment-10193844
If you're not planning on OC and if this is your first computer build, I would just say use the pre applied.
If you do plan to OC you might want to buy some thermal paste and replace the pre applied.
Specs
i9 9900K 5.1GHz 0 AVX offset
ASUS MAXIMUS APEX XI
Custom watercooling (360mm, 60mm thicc)
EVGA GTX1080 FTW DT
EVGA T2 1000W Platinum PSU
3200MHz G.Skill RGB B-die
Samsung 970 Pro 512GB
Samsung 860 EVO 2TB
Crucial MX300 1TB
https://linustechtips.com/topic/812253-thermal-paste-advice/#findComment-10193895
my experience is they come with decent pre applied paste.
buuuut you should always have some paste in your toolbox.
If you are overwhelmed about all of the options and the performance differences, get arctic silver 5 and move on with your life.
https://linustechtips.com/topic/812253-thermal-paste-advice/#findComment-10194424
