What's a good cooler for a Ryzen 7 1700X?
Solved by Damascus,
1 minute ago, will0956 said:I wouldn't want to risk destroying a $100+ cooler, but I'd be willing to try and see if I can get it to fit
Celcius series are designed to be tinkered with but of that makes you uncomfortable one of the cheapest aio's around, the maelstrom 120t or something like that has super flexible tubing.
If you get a 120mm aio you can actually move it to the right side 120mm bracket to see dem RAM sticks
