I'm trying to get a few extra miles out of my EVGA GTX 980 Classified, before upgrading to the 1080 ti.  Not a fan of the PrecisionX software, seems buggy and the overlay doesn't seem to work half the time.  Will Afterburner apply overvoltage?  The slider is available, as I've unlocked voltage control in Afterburner settings, but it's not applying it.  The voltage stays at 1.2v.  I'm able to get 1498mhz on the core, and 3993mhz on ram at the 1.2v, but even under heavy load, the card stays in the high 60's.  So I have some headroom I would think, right?  Power and temp limit sliders are maxed at 125 & 91c.  Of the three bios settings, normal, OC, and LN2, I have it selected to overclock, which I would think is altering fan curves and tdp limits?  I called and asked a MSI rep if Afterburner would in fact apply voltage to a EVGA card, and he said no it would not, but I wasn't sure he actually understood what I was asking, as there was a bit of a language barrier.
Appreciate any tips, thanks.  :)
3 hours ago, DaveImagery said:
Get Precision X and overvolt it that way. You can go all the way to 1.3V. The Classified Controller is even better though. Can tweak memory and PCI-E volts too. OCP and Vdroop is also available.
https://eu.evga.com/precisionx/
right underneath where it says 980 Ti Classified tools download the zip which has Classified Controller
http://www.overclock.net/t/1411500/official-evga-classified-k-ngp-n-owners-club
Yeah I'm not a fan of the Precision X software.  Does it actually go to 1.3v, or is it just reporting that it is?
Can the Classified controller be used in conjunction with Afterburner?  I see it's only for adjusting voltages, you will still need an app to adjust frequency.
The old Precision X though. Not the newer variant is still better. Precision X properly goes to 1.3V.
Classified Controller should work with Afterburner.
Thanks for the help.  So far 1560mhz is stable, but I dare not go any higher on air.
