Just wondering. Looking to get one soon, and if its worth the risk.
i7 7700k OC 4.7 GHz | MSI Gaming M3 Z270 | Corsair H100i v2 | MSI 1080 Aero | Seagate 1TB 7200 RPM HDD + 256 Samsung 850 EVO SSD | Cooler Master Mastercase Pro 5 EVGA 600B | Dell S2417DG 1440p 144hz, BenQ RL2455 | Corsair K70 RGB LUX | Razer Deathadder Chroma | HyperX Cloud Alpha
https://linustechtips.com/topic/809814-how-often-do-aio-coolers-fail/
I bought a refurbrished one that lasted me for about a year and a half. Could only imagine it lasting for more than two years at least.
Current Build
Successful Builds
I'm more worried about it failing and spilling everywhere. I've had very bad luck with PC components coming DOA
Its a hard question to ask. Manufactures build things with a certain percentage expected to fail before warranty is up. You could have one that dies within a few weeks/months, or one that lasts you 3 or 4 years.. its really a hard if not impossible question to answer.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
for aio's, they seal it pretty tight. I tried salvaging the radiator from mine and ended up ruining the tubing :P
Current Build
Successful Builds
with AIO's it is quite rare for them to form a leak these days. You are more likely to have a pump die on you than it to leak.
Community Standards
"Beast Mode"
Would you recommend an AIO over air?
If warranty period is any indication, Corsairs AIOs "should be good" for 5 years at least. Usually it is the pump that dies though, rather than leaks per se.
If you get a good air cooler, alot are actually better than some AIOs. Air coolers such as the Cryorig R1 Ultimate, Noctua NH-D15, Phantek TC14 etc...
Community Standards
"Beast Mode"
A top end air-cooler will perform close to a 240 mm AIO. It is however much heavier and risks unmounting if you move your rig too much. On the otherhand it doesn't it doesn't leak (no fluid, hah).
AIOs also take less space around the CPU socket, but also requires space for a radiator mount. 120mm radiators are completely not worth it though.
2 minutes ago, FiveNine said:
You seem like the type of guy that worries about these things. If you want peace of mind, get air and never worry. It's cheaper, on par with performance, quieter, looks worse most of the time..
Yeah i'm just paranoid
Worth is relative. What's worth it to someone else might not be worth it to you ;)
Depends on the aesthetic you want. These days that's the only real difference.
That's only true if you ship it, with very shitty packaging, and a rough carrier. The chances of you shaking it off your board from moving your rig around are very, very slim.
Truth.
Though a good air cooler will cost about as much as a lower end liquid cooler.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I've had a antec kühler h2o 620 leak, it made a puddle on one of the ram heatsinks on a 90deg rotated board.
And now my H55 is sort of failing after exactly 3 years, 3930K hitting 70C+ under half load, tried multiple remounts but they did not help.
After looking up some teardowns you can see the radiator is made of aluminum, the block made of copper, and they used anti freeze and maybe something else as inhibitor, and eventually they gunk up. you get the idea that these were never made to last forever.
I'm currently thinking about taking the h55 apart, remove the weaker pump impeller, replace the radiator with a copper one and then run it with the spare pump/res combo i have lying around.
CORSAIR Coolers have a 5 year warranty and if they happen to fail (very low percentage), send it to us and there's a possibility of us swapping out your ruined hardware. We'll basically replace anything that was ruined.
To answer your original question, they're very reliable. Most of the people who write reviews or chime in on forums that have negatively experiences are quite vocal, however they represent a very very tiny percentage of people. Everyone else who has a fully functioning 3-4 year old unit don't really chime in all that much.
