power supply enough for overclocking
Solved by STRMfrmXMN,
20 minutes ago, NewBieDavid said:But even overclocking without touching the voltage settings ?
Because as far as I know you can overclock a little bit without having to raise the voltage which what cause the heating issues right ?
Maybe attempt to overclock as far as my stock voltage allows me ?
You can try overclocking without adjusting voltage but you'll likely hit a wall pretty quickly
