Temperature way too high after switching to liquid cooling
9 minutes ago, For Science! said:Its a lot of paste, but that is fine, as long as it is not too little, which is what I wanted to confirm.
1. You're particularly unlucky with TIM lottery for the 7700K. This could be the reason for your random core temperature bump at idle. I had them too before delidding, but I think it wasn't nearly as bad.
2. What fans are you running at what rpm? The PE radiator isnt the slimmest thing and coupled to the dark base case, I wonder if you are approaching the realms of passive cooling.
3. No idea about netflix, but I wouldn't have expected it to be heat inducing. I suppose your utilization is on the high end because you are using integrated graphics at the moment?
4. Are you using the correct jet plate and jetplate insert on the EVO doe LGA1151? I know theres a few selections, but I dont know what it comes out of the box.
If its any reference, after a healthy gaming session of Fallout4 with 2x 1080's in SLI, 7700K @ 5GHz (1440p, about 120 fps average), my water temperature is about 45 degrees. I make my fans ramp up to keep the water temperature exceeding 50 C. So I would be very surprised if netflix is putting anything close in terms of load.
Ok... I have no Idea what just happened. I restarted my PC and the Utilization was in the 50s... I checked what it was. Asus Aura and Logitech Gaming Software Service. Both about 15%. I checked and both programs are known to put load on the cpu. But the utilization before was good. (10 to 15%, not great but ok) So I closed both services and Temperature went down to 40 with the lowest possible fan speed and 30 with full power... I guess thats fine. But I have no idea why this problem started just after installing the liquid cooling and was shown in CPU Utilization just after I took the pictures for you and not before... I hope that fixed it... Now during benchmark you can actually see the increased temperature as you should... Very weird behavior.
