Poll: A few questions regarding Threadripper vs i9
62 members have voted
  1. 1. Do you think that Threadripper might actually have higher single threaded performance then the higher core i9s, if the i9 thermal throttles?
    • Yes.
      28
    • No.
      29
    • Intel is not that stupid, they will use solder as the TIM with their higher core i9s.
      5
  2. 2. Do you think that Threadripper will thermal throttle?
    • Yes.
      11
    • No.
      51
  3. 3. Do you value IPC and clock speed, or more cores?
    • I greatly value more IPC and clock speed over more cores.
      9
    • I slightly value more IPC and clock speed over more cores.
      11
    • I'm pretty neutral, as long as it can run crysis.
      21
    • I slightly value more cores over IPC and clock speed.
      16
    • I greatly value more cores over IPC and clock speed.
      5
  4. 4. Do you value PCIe expandability?
    • Yes.
      35
    • Somewhat.
      18
    • No.
      9
  5. 5. If you had to choose between i9(Skylake x i7) or Threadripper which one would you choose?
    • i9(Skylake x i7).
      18
    • Threadripper
      44
Take a look at this video:
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
I think Threadripper will absolutely thermal throttle if you run it with these:
35-708-011-02.jpg?w=660&h=500
Which is to say, that's a tad oversimplified.
"Do as I say, not as I do."
-Because you actually care if it makes sense.
If any CPU is thermal throttling that means you have insufficient cooling.
So I'm kind of anoutlier in a few questions so I'll say my answer and why I think it.
1. I think AMD doesn't have better single core performance. With the FX series and now ry zen having worse single core performance says they won't have better than Intel single core performance but I think amd is getting there. It'll definitely be closer to Intel but not as good. AMD seems to design around prioritizing multiple cores to run better than every core doing something different. Yes they're great for doing different things but more so engineered to work together. In my opinion and observation.
2. I think theeadripper as any component will thermal throttle if they get hot enough. I thought it was a safety feature built into most if not all modern components.
3. Ivalue more cores because I think it's more efficient than clock speed alone. I may be wrong scientifically but for multi tasking and heavy workloads I think it's better. (I'm American... we drive pickup trucks everywhere! We're not hauling anything. We just went to mcdonalds cuz we were hungry.) although I do only have a 4 core i5. It's good enough for me, but I really want more cores. Oh well. Maybe when the i5 isn't good enough anymore.
4. I value Pcie expandability because I think it's better than having a bunch of USB plugs in the back of the computer. Also: it's faster.
5. I would choose threadripper because it USB cheaper, and has wayyyy more cores than I need. I9 may have more less or the same.. but I don't have endless money. If i9 was cheaper or more competitively priced I'd consider it but I cannot afford either.
Do you believe that Intel not using Solder as their TIM between their die and heat spreader could cause more insufficient cooling?
If so, then outside of delidding the CPU there is not much that the consumer can do.
That's why I said if the i9 thermal throttles.  If it doesn't, the i9 has both an IPC and clock speed advantage.
The only advantage that the i9 looses if it thermal throttles, would be clock speed.
I may not have been clear in my questions, Skylake x, in particular, has a hard time keeping cool.
http://www.tomshardware.com/reviews/intel-core-i9-7900x-skylake-x,5092-11.html
3 minutes ago, Cinnabar Sonar said:
That's why I said if the i9 thermal throttles.  If it doesn't, it has both an IPC and clock speed advantage.
Why would you ever compare a throttling CPU to a non-throttling one??
It should never throttle unless you make very bad buying decisions.
"hmm i wonder if my honda goes faster than ferrari with no wheels..."
Image result for thinking
I asked you a direct question regarding this, i'll ask it again.
Unless you consider Intel's Skylake x lineup, a bad buying decision, there is not much that the consumer can do outside of buying a very expensive cooling solution, or delidding.
I asked you a direct question regarding this, ill ask it again.
What do you mean "insufficient cooling"??
Does "I need an AIO instead of an air cooler to cool this CPU" meant it is insufficient cooling?
Do you consider a 9590 to have "insufficient cooling" because it needs a high end cooler?
Maybe you don't understand, but the cooling is provided by a cooler OUTSIDE of the CPU.
Whether it is soldered or not just determines if it will run a few degrees hotter or not.
There is always going to be a cooler that can cool a CPU enough for it to run normally.
These are consumer CPUs after all.
Tomshardware seems to be having difficulty even with AIOs, and while you stated that "Why would you ever compare a throttling CPU to a non-throttling one??"  I would have to disagree.
If threadripper can maintain it's temperatures more than Intel, on the same cooler.   It's definitely worth discussing, and should be a factor when buying a new CPU.
That's for overclocking.
Obviously if you take a 140W CPU and overclock it it's gonna use way more power and create way more heat.
It's completely illogical to overclock your CPU to a point where it throttles, because it's completely counterproductive.
You would get better performance at stock or with a lower OC than forcing it to throttle.
You can take any CPU and overclock it to the point where it throttles.
There is no point in comparing a throttling CPU to a normally functioning one.
There IS a point however to compare an overclocked CPU to a stock one, if for some magical reason Threadripper is so efficient that you can OC multiple times better than Skylake X.
If you take a certain cooler and compare both CPUs with the highest overclock you can get on that cooler then sure, that's fair.
Asking if one CPU throttling will be worse than another CPU not throttling is not the correct way to ask that question at all.
There IS a point however to compare a an overclocked CPU to a stock one, if for some magical reason Threadripper is so efficient that you can OC multiple times better than Skylake X.
If you take a certain cooler and compare both CPUs with the highest overclocked you can get on that cooler then sure, that's fair.
Ok, we seem to be somewhat on the same page here.  Another question for you.
Do you think that the higher core i9s coming out will be able to match threadrippers clock speed without throttling?
No overclocking.
No overclocking.
So stock i9 vs stock threadripper?
From what I've found online, Threadripper is 3.5GHz base 4GHz boost, and the 7900X is 3.3GHz base 4.3GHz boost.
So yes, both have very similar clock speeds without throtting.
IPC however will still be higher on intel almost certainly.
How much Threadripper can OC compared to i9s will need to be tested when Threadripper gets reviewed.
If it can OC much higher on the same cooling, then it's always possible it could match the IPC of an i9 with a small OC or stock.
I seriously doubt that threadripper will overclock well.  Ryzen didn't and Threadripper is basically two Ryzen chips hooked together through AMDs infinity fabric.
I was mainly talking about Intel's 7920x and up, while we really don't know much about them other than price, if Intel's CPUs are having thermal issues(even if its only limited to those that overclock) then I don't know how Intel will be able to have 12, 14, 16, and 18 core chips that match Ryzen's clock speed.
The 12 and 14 core CPUs might.
https://www.extremetech.com/computing/252354-investigations-sheds-fresh-light-intels-x299-overheating-problem-implicates-skylake-xs-design-well
Another article, I believe that this issue may become worse with Intel's higher core CPUs.
Ok so then like most xeon CPUs, you don't overclock them, or you OC them very little, (unless you have phase change cooling or a massive custom loop).
Boom, no thermal problems.
Clock speed is not the only thing that matters for IPC so it's useless to compare clock for clock.
You need to wait for benchmarks to know if Threadripper will be better or worse than a slow clocked i9.
If you compare the low clocked 6950X to Ryzen, it still has better single core performance.
TBH everyone should just stop comparing unreleased CPUs until real tests are done on them to know actual performance.
X299:
-Contrary to popular belief, it runs really well, and of course it produces heat when overclocked, people are just shitting on it for no reason.
-Get a decent motherboard, and a high end CPU, or just stick to mainstream i7-7700k.
-Decent motherboards have no VRM problems (they cost more though, and the cheaper boards aren't "crappy VRMs", it's just that their best most high end VRM's before they had to put better ones on there just aren't capable of handling so much.
Threadripper:
-Less IPC, obviously, it's not a debate, it's ZEN based, and can't clock higher than intel's chips, so they opted for more cores to keep up with the better price / performance ratio while making a profit.
-It is suitable for those who want more PCIE lanes for less than 1000+$$$
-If you want pure performance for streaming, etc, Get a Ryzen 8 core, or a i7-7700k, that's all you need
Neither platform is bad, Threadripper offers more PCIE lanes, and X299 offers more single core performance (maybe 20% if you overclock, 11 - 13% if you don't)
Those numbers are off the top of my head, they are probably highly inaccurate for IPC%, but it's really not too noticeable.
Anyway, the cheaper option is threadripper, and the "better" option is Core i9, X299.
Look at it the way you look at Ryzen, and it's the exact same, Ryzen offers more cores for the same price, or simply the same amount for less.
CPU: AMD Ryzen 5 1600 @3.7ghz (1.3v) Cooler: NZXT Kraken X62 GPU: Zotac Mini GTX 1060 Case: NZXT - S340 (Black/Blue) Mobo: MSI B350m mortar arctic
RAM: Team Vulcan DDR4 (2x4gb, 2666mhz) Storage: Toshiba 1tb 7200rpm HDD, PNY CS1311 Sata SSD (6gb/s) PSU: EVGA - BQ 500w 80+ Bronze semi modular
You are right, however clock speed is a factor.
Can you link me the website that says this?  That would be very informative.
It's going to happen, I don't think that speculation is necessarily a bad thing, as long as people don't state things as fact, I'm OK with it.
5 minutes ago, NoMercy said:
You guys should not have the word "throttling" in your discussion. It doesn't make sense?
Care to give me a better word to use?
Nvm I remembered wrong, it's the 6900k that has better single core.
Image result for 6950x vs ryzen single
Still, it has lower base and boost clock speeds than the 1700/1700X.
Informative nevertheless, thank you.
16 minutes ago, He_162 said:
X299:
I am assuming that you are talking from personal experience?  I do have interest in the 7820x, and I would love to know your experiences with the platform.
Also, my intention was not to "shit" on the platform.  I am sorry if you got that impression.
If you put both CPU's at the same clock speed and measure single core performance, you're getting the IPC. That's benchmarks.
Now if you take the overall score and divide it by the cores, you can get a similar metric for IPC, although not as accurate.
i9-7900x = 2167 in cinebench. / 10 = 216.7 (@3.3ghz)
TR1920x= 2431 in cinebench. / 12 = 202.6 (@3.5ghz)
Threadripper was clocked slightly higher across all cores, but it seems like it's within 11% of X299 / Skylake-X's IPC if it's anything close to accurate.
And you're literally telling people not to compare products when one is clearly better price to performance, and you can figure out things like relative IPC, overall IPC, and how well it does in the cherry picked benchmarks, which is silly, conversations should be had period, and it's not something we should just "stop and accept whatever the reviewers say".
I was told Ryzen sucks at gaming until I bought it, and found out not only was it smoother, but no one mentioned the fact that it doesn't matter what the max framerate is if you don't have a GTX 1080 Ti, or 240hz monitor.
To the good chunk of people who think Threadripper will have better single-threaded performance than Skylake-X; just why?
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
I do not have X299 on hand, I am referencing reviewers, and overclockers, such as Der8auer, and videos such as this:
I should also mention that he is an AMD fanboy for the most part, and he doesn't give much praise to the stock settings for this CPU much.
No clue, optimism I guess?
It clearly doesn't.
Better single threaded performance if and after Skylake x thermal throttles.
While this is an issue already, the higher core Skylake x chips that are coming out may have this problem even more.
Skylake x has better single threaded performance when running at full speed, that is clear.
