Don't pay attention to ms, it means nothing.
What you should care about is input lag which you can find in reviews.
No, you cannot tell the differences. You should ignore response times for the most part for many, many reasons. There's a good monitor FAQ pinned to the top of the displays subforum that you should read, it covers response times there. I've typed out the reasons for ignoring response times so many times now, I'm just directing to the FAQ because it answers the question well.
Just for reference, the difference between 1ms and 5ms is 0.004 seconds.
do you have a recommendation for 1080p monitor ? thanks!
Depends on your budget and most common workload.
For a great all-rounder, I'd recommend the Dell U2414H as it's good at everything. For pretty much entirely gaming though, you may want to consider a 120/144Hz monitor, though you will have to settle for TN in that case, so colours won't be as good.
i don't mind the colors, my idea is gaming! and some school stuffs hehe. thank you for your suggestion :)
21 hours ago, Bcat00 said:
Yep dell ultrasharps are definately a solid all rounder monitor, been using one for a while now as my second monitor.
too bad youtubers don't cover dell monitors so much. but nah who cares ima buy one Haha! thanks for your reply man.
Dell is really one of the best monitor manufacturers out there in terms of reliability and track record. They're generally sensible and practical monitors without LED logos being projected under the stand *cough* ASUS *cough*. The more minimalist and simple style fits some better, like myself, but doesn't really get the hype that the GAMING 23,000 0.01ms marketing BS monitors get.
