Need Help With Mixing Metals in a loop
Hello!
I'm new to water-cooling and am looking to build my first loop. Since I am super cheap I am trying to buy parts for as cheap as possible. Because of this, I don't want to buy the "standard" EK Pump/Reservoir that matches the rest of my copper stuff. Instead, I found an XSPC X4 Photon 270mm Reservoir/Pump (aluminum I think). My problem is that I have a copper water-block and radiator. Will the aluminum pump/reservoir hurt my loop? If I use an anti-corrosive fluid will it be ok?
Thanks for the help!
lahren1
The first step is to not cheap out when putting water inside a PC.
If you have a small budget you should stick to AIOs or air cooling.
An anti-corrosive fluid will only slow down the corrosion process. Mixing metals is something everyone advises against. Watch Linus's video on EK's budget water cooling loops. They are made of aluminum and shouldn't be mixed with copper or other types of metals.
I5 6600K @ 4.6 Gigahertz
Cryorig H7
EVGA GTX 1070 FTW @ 2 Gigahertz
16 Gigabytes of Corsair Vengence
ASUS Sabertooth Z170 S
Crucial 525 Gigabyte SSD
Hitachi 1 Terabyte Harddrive
NZXT Hue+
NZXT H440
Corsair Rmx 650 Watt Power Supply
Get the new aluminum ek kit's.Problem solved
My life
  • Bracket Material: Aluminium
Where did you read that the internals are aluminum?  Nothing is aluminum really except the stuff straight out of China.
Workstation:  14700nonk || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 9900nonK || Gigabyte Z390 Master || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3080Ti Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
The res is fine, a cursory look at the page says the only aluminum is on the external brackets.
Want to custom loop?  Ask me more if you are curious
I believe the photon is acetal body and aluminum brackets, nothing that should touch the water or cause concern.
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
Thanks everyone!  I appreciate your replies.
