Microphone and headphone questions
Solved by doits,
You can go with either scarlett interface and at2020 xlr will be a great setup. Pick either of the headphones and just try it out. If it doesn't get loud enough for you then add a cheap fiio amp. If you use the headphone amp you will plug headphone into amp and use 1/4 to whatever input on amp. This will amplify the signal and allow you to still monitor mic.
Or you can go the usb mic option, and use the saved money toward a nicer pair of headphones or earpads or audio foam or whatever. I personally use the at2005 with usb/xlr output and you can add an interface later if you feel the need.
edit:painting is fine see this video.
