Anyone know if the Thermaltake View 31 http://www.thermaltake.com/products-model.aspx?id=C_00003012
Can fit the X99-E WS? That motherboard is 12 x 10.5. That's less than an inch wider than ATX. I don't care if it covers up the cable grommets, I just want to make sure they aren't raised or in the way.
https://linustechtips.com/topic/806684-thermaltake-view-31/
If it's an ATX form factor it should fit
https://linustechtips.com/topic/806684-thermaltake-view-31/#findComment-10136578
