I was wondering about how well the CX450M would hold up with a gtx 980, 7600k machine. Specifically overclocked at a constant 400w load. This stupid mining craze is pretty much forcing my friend to wait at least another month for a 1060 or bid on a 980 now.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
https://linustechtips.com/topic/803757-cx450m-load-safety/
It will be more than fine.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/803757-cx450m-load-safety/#findComment-10103305
it should be ok, if you want to play it safe dont OC
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/803757-cx450m-load-safety/#findComment-10103316
The cxm 450 are very OK PSU's.
You could probably run at full load and wouldn't kill it any faster than half.
That said, The worst that can happen is the psu gives out(cant provice enough power) and the system crashes. He'll need to return it and get a 550 watt PSU.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/803757-cx450m-load-safety/#findComment-10103329
I don't know if I'd quite risk it for a prolonged period of time on a CX450M, I'll be honest. I think newer revisions come with some decent safeguards, but a lot of the margin people have for wattage is for thermals as well. That being said, a 980, even with 2GB less VRAM is quite a decent bit faster than a 1060, so it's not a bad buy at any rate. So if your buddy is in a hurry, and doesn't have much use for the extra VRAM, it's not a bad thing if he can find the 980 cheap.
That being said, I don't wanna be that guy, but in these cases I always squeeze in a disclaimer about not taking PSU choice lightly. It's not just about adequate wattage.
EDIT: It just dawned on me, does the CX450M even come with an adequate number of connectors? Depending on the 980, it could be 1x8-pin + 1x6-pin or 2x8-pin. If the PSU doesn't have the adequate connectors, I definitely would stay away from anything that would require you to use some janky molex to 8-pin adapter. You really have to make sure.
OS: W10 | MB: ASUS Sabertooth P67 | CPU: i7 2600k @ 4.6 | RAM: 2x8GB Corsair Vengeance 1600mhz | GPU: x2 MSI GTX 980 Gaming 4G | Storage: x2 WD CB 1TB, x1 WD CB 500GB | PSU: Corsair RM850x | Spare a moment for Night Theme Users:
I'm an erudite cave-dwelling Troglodyte
I frequent LinusTechTips past midnight
Dark backgrounds I crave
For my sun-seared red gaze
I'll molest you if you don't form your text right
https://linustechtips.com/topic/803757-cx450m-load-safety/#findComment-10103372
many of the lower tier model 980's have 2x6 pin so I was just wondering if many people has enough experience with the cxm models to give a good opinion. I figure it will be enough myself, but I wanted to hear other opinions.
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/803757-cx450m-load-safety/#findComment-10103448
Well, everyone gave a tentative "it should work" more or less. At peak system load with a setup like that you'd see much less than you'd think, especially at stock. Just depends on the version of 980 and the connector combo. Even the reference card is 1x8 and 1x6. The only version I can remember coming with 2x6-pin connectors was the EVGA SC one IIRC, but yeah I guess there could be more.
https://linustechtips.com/topic/803757-cx450m-load-safety/#findComment-10103529
Just now, LooneyJuice said:
Well, everyone gave a tentative "it should work" more or less. At peak system load with a setup like that you'd see much less than you'd think, especially at stock. Just depends on the version of 980 and the connector combo. Even the reference card is 1x8 and 1x6. The only version I can remember coming with 2x6-pin connectors was the EVGA SC one IIRC.
That was the exact one that I'm trying to get him to bid on. A 980 with 2x6 pin seems perfect for him. Now just to get him to return that 7600k and buy a used 6700k instead.
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/803757-cx450m-load-safety/#findComment-10103535
I wouldn't personally pair a 450W PSU with a 980 but it's not like a 7600K and 980 will be breaching 400W so you'll be fine. The CX450M is a good unit too.
https://linustechtips.com/topic/803757-cx450m-load-safety/#findComment-10104356
