Best Cpu cooler for r7 1700
DekaRanger
Hello.
I am wondering what is the best cooler for the r7 1700. What is the best cooler so that I can see the all the ram slots, cool and quiet? I have been looking at the Cryorig R1 Universal but have read that the slim fan is somewhat noisy.
If I missed anything important just ask. Thank you in advance.
if you want to avoid all ram issues and want some high quiet clocks i would recommend a 240 aio or similar
5 minutes ago, DekaRanger said:
Hello.
If you're looking at the R1, I'm assuming you're overclocking? The stock cooler is capable of a decent overclock if your motherboard doesn't suck, and the Wraith Spire looks sexy with its RGB ring. Oh, and it's quiet.
If you need something beefier, the Cryorig H7 is designed for zero RAM interference. An AIO might actually be the best bet of all for you if you want quiet, full visibility of your RAM and a hefty OC.
Aerocool DS are the best fans you've never tried.
Either an AIO, Hyper 212 Evo, or the BeQuite! Dark Rock Pro 3.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
8 minutes ago, Mi26 said:
Hyper 212
-rep.
Theres better coolers for the money
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
I am overclocking. I forgot to mention that, my apoligies. I was thinking about an aio but they cost 40$+ compared to the most expensive air cooler(nh-d15). Is it possible to get something beefier than an H7 and still  have no ram clearance issues?
or what about the noctua cooler that is slightly pushed over to give more clearance, sorry that i cant remember the model number
If you want an aio I recommend the Celsius s24, if you're more into air cooling nh d15 for performance or dark rock pro 3 for silence.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
212 evo is barely better than stock :P
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
Eh that is hard to believe but maybe.
its true due to radiator thickness and how the stock blows directly onto the packet removing heat dierctly by skipping the heat pipes and stuff
I was thinking about the dark rock pro 3 aswell but it covers the first ram slot and the d15 fans ruin it for me.
spray paint? or possibly electrical tape
I would rather not modify things like that since I am no handy man and would like to just put everything together and not having to do anything extra.
Perhaps you could move the back fan to the front? There's a mounting area on the front for another fan so you could just move the blocking fan there instead for the dark rock pro 3.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
im not either which is why i used tape for first installation and then one year after when the tape began to flake i bit the bullet and it worked perfectly so my advice is be careful and precise and use lots of tape to cover the fan hub and you have little to no chance of significantly damaging your fan
I don't mean to be rude but I didn't understand anything of that.
47 minutes ago, tom_w141 said:
Stock cooler is pretty good, otherwise I suggest an AIO such as the cheaper deepcool captain. Large air coolers are good but may obstruct RAM
Noctua NH-D15 is not too bad if speaking about RAM clearance
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
Like
  ___   ___
(excuse the poor drawing)
Assume each of the column of dollar signs is a fan, the column of number signs is a space where you can put a fan (but is currently empty), and the little corridor things are the sticking up radiators. The dark rock pro 3 has three fan mount locations, two of them come populated with fans (the $ signs).
One of these fans is blocking your ram slot, let's say it's the one on the far right. There are fans in the middle and on the far right. What you could do is take that one on the far right that's blocking the ram slot and moving it to the far left insteads, so that it would look like this instead.
  ___   ___
(Again excuse the poor drawings :P)
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
H5 Universal would be my immediate response, but then you're back to the thin fan that's a bit noisier.
Top-down coolers like the NH-C14S or C1 are also options here, I'd think, but you're paying a premium for those and the performance doesn't really warrant it.
What case and ram are you using?
Can you link us to where you're shopping?
