Left thermal paste in hot car is it still good
VoidJasper
As the title says i left thermal paste in my car for like a month straight and its just been baking in my hot car will it still be optimal to use?
It should be good but thermal paste expires in about 1-3 years so it should be fine
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
If it didn't show signs of "melting" (or changing color) it is still good as before. It did happen to me too.
I'm sure its fine. Its job is to conduct much higher levels of heat, so it should still be good for use.
How hot does it get in the car? I'm guessing not as hot as CPU/GPUs that it would be used on. It'll be fine.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
if it's quality paste (you know, something like "MX-4 or similar/better") it's made to resist years of temperatures WAY past what your car can reach.
if his car reached 95°c his dashboard would be melting :P
Just now, M.Yurizaki said:
I've used 5 year old AS5 (still in its tube) to good effect so...
I was just guessing but it varies from brand to brand
Check what it says on tube about min/max storage temps. The paste itself can take the temps. But tube might cause altercations.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
