help Help purchasing a router for home wifi
49 minutes ago, Lurick said:Look into the ubiquity lineup and setup a mesh network.
Why is mesh the flavor of the month all of a sudden? I know that it's being pushed heavily by Google, Ubiquiti and others but it really isn't the silver bullet you think it is. Mesh is essentially a set of intelligent range extenders and it's no better than a range extender for <4 nodes. Most houses can get full coverage with 2-3 nodes.
Really your best bet @RenaW would be to get something like the AC-Lite/AC-Pro/AC-LR from Ubiquiti but just one of them. Use it to replace the WiFi built into your router and place it high up on the wall above where your router lives. It will be miles better than what you have. If that doesn't cover your house well enough? Look at getting a second one. Ideally connected via Ethernet but if not try Powerline or, worst case, set it in isolated mode and have it behave as a repeater. The last option is only for if the other options aren't possible. Only get their Mesh AP if you like the idea of a outdoor rated AP and are willing to spend more for it....
