Hi All,
I've been in a lot of long car trips lately and I'm wondering if it's possible to to build a small form factor gaming pc to sit in the car and be powered off a USB cable and if so what kind of parts would be uesed. And if not would a small affordable ups be an option?
please help,
all thanks in advance
BDunkz
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/
Raspberry Pi.
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10088725
Just now, Abyss Gaming said:
He said gaming tho...
He can play minecraft on it.
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10088731
2 minutes ago, BDunkz said:
How about an affordable ups?
A UPS is only made to run a PC for a few minutes during a power outage so you can shut it down.
It is not for making a PC portable.
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10088745
Just now, BDunkz said:
That was my other thought, could you recommend any reasonable priced ones $100. The only thing is I've just finished my gaming pc for home and …
for 100$, a raspberry pi handheld would be easy to obtain, what game are you planning on playing?
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10088756
well, there's either a laptop or getting a serious battery bank to power a pc and monitor. The first would be cheaper...
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10088827
$100 laptop capable of gaming?
Probably a off-lease ThinkPad T420 off of eBay, but even those tend to be more than $100, and they have no graphics card to speak of.
No matter how you do it, you're going used, and you're going to be limited to very basic games by the graphics of whatever you end up with. APUs are also an option if you can find one cheap enough. I had a Toshiba 17" laptop with an A8-6410P (IIRC) that could run Skyrim at 720p low settings reasonably not badly, but even that would be pretty far above $100. I ended up selling that laptop about 6 months ago for $150.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10088834
Convert your current rig into an usff and use a pure sine wave inverter(400watts) to power it. Grab a USB 720p display for $100 on amazon and you're set
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10088855
1 hour ago, BDunkz said:
Hi All,
please help,
BDunkz
Power inverters come in a variety of sizes.
https://www.amazon.com/BESTEK-Power-Inverter-Smart-Adapter/dp/B01DP9JE18/ref=sr_1_2?ie=UTF8&qid=1499134644&sr=8-2&keywords=BESTEK+300W+Power+Inverter+Dual+110V+AC+Outlets+and+4.8A+Max+Dual+USB+Ports
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10089068
Sorry I meant $1000
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10089398
10 hours ago, BDunkz said:
Sorry I meant $1000
Plenty of laptops out there in the $800-1,000 range that have a quad i5 and a 1050 in them. MSI, Dell and Acer all make one, I believe, and you can get a decent power inverter capable of handling any of them for less than $100. That's your best option by far.
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10091059
So convert my current pc into a small form factor and get an inverter?
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10092782
If your current pc is drawing anywhere near 300W or more you will need to install the inverter with a direct battery connection.
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10093038
I still feel like saying, "This is what laptops are for," but yes, you could build a SFF gaming PC for under $1K that uses less than 300W. I did.
https://linustechtips.com/topic/802417-running-a-pc-in-a-car/#findComment-10093363
