i7 920 temps - 70-75* load
Emillionaire
Hi, i have a pc running with an i7 920 (and gtx 960)
Currently its cooled by a cooler master HAF TX3 cooler,
but i am getting a load temp (Playing overwatch) on 70-75*C. I intend to sell the pc, but i do not want to sell a crappy pc.
Is the temp okay, or should i upgrade to the hyper 212?
Would there be a diffrence?
Yes, the username is cringe.
Temp is more than fine.
(also never buy a 212 evo)
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Okay, whats wrong with the 212 Evo?
Nothing other than the trash mounting system.
There are just far better options such as the Cryrogi H7 or BeQuiet! PURE ROCK and a few others
the one with the trash mounting system is the tx3
Nope, Owned a 212. Mounting it is fucking stupid
Yeah, ands its awfull!
Reinstall took me 10 tries when reapplying thermal paste. Almost broke the plastic.
tx3 is worse
exactly my problem the pins where too weak for the cooler and were bent so it took me an hour one time to install it again and thats why i decided to invest in a decent cooler
Temps are fine. And upgrading to 120mm budget cooler wouldn't change that much that it would be really upgrade anyway. Let the buyer get better cooler if they want to.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Those are barely better. Asides from better mounting and being a bit quieter, the 212 Evo is nearly equal.
What plastic?
What plastic?
The H7 will usually result in 4-5C lower temperatures while being much quieter. I call that pretty more than barely
Asides from TechPowerUp's review here: https://www.techpowerup.com/reviews/CRYORIG/H7_Universal/6.html, the difference shown between the H7 and 212 Evo's performance usually smaller than 4-5c. The test results of the NH-U12S performing similarly or even a bit worse than the H7 is particularly strange and is inconsistent with most results from other benchmarks and reviews.
https://www.overclock3d.net/reviews/cases_cooling/cpu_air_cooler_mega_test/39
http://moddersinc.tumblr.com/post/143201459093/sectiontitle-title-introduction-and
I've had both the H7 and a CM 212+. The H7 is the better cooler, but the 212 had the better mounting. I would buy either again.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
