Why are all cpus built with cores all at the same speed?
10 minutes ago, jiminy said:Is it possible to make two cores with a given speed take up less space than a single core which is twice as fast?
Strictly speaking of Intel(AMD is probably the same). When they make a CPU it is done on mass. It would be harder and more time consuming to make different cores on the same die. Also most lines(kabbylake, skylake) of processors are the same processor cores. The clock difference comes from quality control. A really good processing core will go in a high clocked k. A lower quality core will go in a lower clock non k processor. https://www.quora.com/How-does-Intel-design-and-produce-so-many-models-of-CPUs
So the different cores are physically all the same size in i3, i5 or i7 in a given line. Besides is a modern CPU really that big?
