Design for 1080ti trisli
Go to solution Solved by Princess Luna,
Founders Edition.
Hi :)
I would like to know what would be the best card design for 3 way sli, I see a lot of people saying reference is the best, but could anyone confirm this? What would be the difference with custom design such as this gigabyte card?
So true it hurts
1080ti 3 way SLI isn't supported except for workstations but founders would work the best in that config
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
or one aftermarket and one with a 120mm rad as exhaust (hybrid one)
Oh yeah that could work
14 minutes ago, tom_w141 said:
Unsupported
Ok I am just asking a question and all I get is useless answers.. You can get 3 and 4 way sli to work in games with Nvidia Inspector. But that's not the question, I want to know if three founder's edition is the best choice for cooling.
Edit :
So true it hurts
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
But why even bother? Your asking a useless question. Its known that SLI past two is garbage, and even two doesnt even scale well in most games, generally its only 20-50%, with some games going higher. Just dont waste your money on this pointless endevor.
Well no it's not an useless question I just wanna know if three FE are the best and if I am not better doing something like 2 FE and 1 custom at top
So true it hurts
Oh well your either a troll or someone really wanting to waste an additional 750$ for 0 performance gain. 3 FES custom loop, otherwise it honestly does not matter what you do.
Founders Edition.
Personal Desktop":
Luna, the temporary Desktop:
1 minute ago, Princess Cadence said:
Founders Edition.
Selected as best answer because she is the only one not questioning my choices, I hope you understand that people do what they want with their money!
Yes I am a big troll.. Or just an enthusiast
So true it hurts
I appreciate it, I would like to point out that since all FE cards are close to the same you should probably go for EVGA as their Warranty and Costumers Support is the best, my brother RMA a 980ti B-stock refurbished with coil whine and they sent us a brand new 1080ti after charging just 200$ price difference, it end up being a 1080ti for 450$ sweet!
Personal Desktop":
