From what I heard the x versions are usually just higher clocked. Considering you are getting an aftermarket cooler, just get the 1700 and overclock. Not too much of an expert on Ryzen TBH.
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036536
Just now, Its Not Important said:
But its virtually the exact same chip right?
Yes, it sure is mate
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036548
Base frequency, if we're being totally honest. X chips don't overclock any better. Trading away a stock cooler in exchange for higher tdp is an awful trade off in some cases regarding X chips vs non-X. (reason I went with the 1600 over the 1600x)
All in all, X chips are not worth the premium unless you have cash to burn or care about XFR.
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036555
How does XFR works? I heard that its only enabled if the CPU detected a high end cooler.... and it only boost 100MHz  on 1 or 2 best Cores (?)
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036573
Get the 1700,the 1700x isn't so worth it for the more money to pay for it.Except if you get it Supercheap
The 1700 is a good overclocker,and comes with a very good stock cooler,for that purpose,the 1700x is basically a 1700 with a better XFR of 50 MHz Lol , but if you decide to overclock the 1700X,that functionality is gone.
PC Specs:Custom Built PC
CPU:AMD Ryzen 3 1200 GPU:Zotac GeForce GTX 1050 TI Mini RAM:Corsair Vengence 2400 MHz DDR4 Motherboard:ASUS Prime B350M-A AM4 Motherboard Case:Corsair 100R PSU:Corsair VS450
Laptop Specs:Acer TravelMate 8472
CPU:Intel Core i5 560M Memory:2GB DDR3 CPU:Intel HD Graphics Case:Its a Laptop Motherboard:Laptop Motherboard
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036577
So it really is makes no sense to but 1700X over 1700 for $70 premium?
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036592
Yeah,you technically answered that xD
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036597
I guess i am getting 1700X at all then if making new system hehe
My head on 2019 :
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036623
$70 + Noctua cooler...
My head on 2019 :
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036626
The 1700 has a 65w TDP and the 1700x has a 95w TDP.
The 1700 has a cooler in the package which is good for up to 95w TDP so basically you can even overclock a bit with the stock cooler, and the stock cooler is actually quite decent (low noise and good performance)
The 1700x has higher "turbo" frequencies because due to the 95w TDP it can afford to use more power.  The 1700 has the peak frequencies limited to fit in that 65w tdp.
If you overclock the 1700, technically you may reach or exceed the performance of 1700x but you're not guaranteed it. If you're unlucky at the silicon lottery, you may get a chip that can't really reach those peak frequencies the 1700x can reach without excessive voltage and power consumption.
Still when you draw the line and factor everything in, the 1700 really does have better value. Worth spending those 70$ difference in something else, like upgrading from DDR2400 to DDR 2933 Mhz  (Ryzen likes high frequency low latency ram, 2667 Mhz should be minimum) or going with a m.2 SSD for better performance.
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036627
Well yeah you make me feel better by saying this, thank you and i guess i am finding a good cooler and 1700x then!
My head on 2019 :
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036665
XFR is AMD's turbo boost where the core overclocks itself during a work load for extra performance by a feww hundred megahertz. Has nothing to do with what cooler you run.
When you overclock, XFR gets disabled so the price premium becomes more if a bad investment between the two chips as both OC the same.
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036668
If i OC the 1700, will it run like that all the time? Or will it downclock on idle?
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036673
I even saw idle at 4GHz using R7 1700, @TheNaitsyrk is the guy
My head on 2019 :
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10036701
8 hours ago, Its Not Important said:
Just a quick and dirty question
Ryzen 1700 or Ryzen 1700X? Which one is better overall? (Both Value and performance per dollar)
Ps: will be using Cryorig H7 Quad Lumi when released
The "X" means "Don't buy this, it's just a test, kappa 123".
Nah, kidding.
Supposedly the X processor is binned to overclock better (like 100Mhz better at most, and is not guaranteed :ph34r: ) IMHO, not worth the investment, buy the 1700.
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10038376
If you overclock Ryzen it will run at 4Ghz all the time (like mine) but at idle power draw is only 20W so it's okay. Temps are low at idle. For me it's about 40-45c. To avoid this you have to do Pstate overclocking and it keeps all the power saving features. Hope it helps.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10041466
I have a 1700 at 3,9GHz (1,325V). It can reach 4,0Ghz but since the voltage was high (1,45V) I'm not gonna use it. My only concern is memory, that is still stuck at 2400Mhz. But, it works great and it outperforms any stock 1700X and is on par with the 1800X. I'd say save the bucks and get a 1700.
https://linustechtips.com/topic/797455-simple-ryzen-question/#findComment-10041475
