I have a proprietary Dell CPU fan that is required for an SFF system. The red wire was ripped off by an angry client and I need to solder a new one on, and these fans are expensive. The only problem is that I can't seem to remove the motor itself to get to the power leads.
Any suggestions?
https://linustechtips.com/topic/795793-remove-motor-from-fan/
Red wire is completely stripped off? Not just cut in two?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10017916
Using something like Belarc (belarc.com) would show you the exact motherboard that you have in your system.  With that information we could hopefully find a pic somewhere that would show what your mobo looked like.  Or, if you could take a close up picture of your motherboard and post it along with the information on make and model from Belarc it would be extremely helpful.  As for removing the fan, somehow it got put in there in the beginning, so there has to be a way to remove it.  Will just take a real close examination of the pics.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10017949
3 minutes ago, H0R53 said:
Completely ripped off.
you can normally get to the solder point wihtout taking the fan apart, but if you can't
Take the sticker off.
Then take the clip off at the back of the bearing.
Then the blades come right off(just pull out)
Then you can get to the motor stator and board.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10017952
RIP.
Maybe someone like @Electronics Wizardy might have some idea?
EDIT: nvm they already are :P
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10017960
The fan has already been removed from the case. Lol. Not a noob here. I literally need to remove the MOTOR from the FAN itself. Int he title.
It's under the board between the plastic and the PCB. I already took the blades off.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10017971
thats gonna be a pain. The board is normally molded into the plastic and a complete pain to get out in one peice. You can try to pry it out is your best hope.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10017992
Just now, H0R53 said:
This is just an example, not the actual fan. I can't get a good angle with my camera to show the problem.
soldering it from the back is you best option, anything else is a huge pain. You can cut away a bit of plastic to make it easier if you need to. I have soldered some nasty wires that have fallen out.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10018014
All of the leads are completely under the plastic base.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10018022
Ah, shit. It snapped off. I can probably use Gorilla Glue, that's what I used for my custom 1050 to mount the LED fan. One sec.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10018033
Well on my test fan you can just pry the controller out and the stator once the blades are out. This one didn't have glue. But many do. IMG_1485.thumb.JPG.60eac418b1c84c5680309c7bad4a339d.JPG
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10018043
Yeah, this is a Dell fan, so it's fucking glued to all hell.
You have nice fingers. No homo. Mine are all scarred and veiny.
I think I have too much solder on it...
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10018070
yep. Solder is like thermal paste. The internel will always argue about how much is right.
id also cut those leads much shorter and resolder, there is just way to much exposed to touch.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10018077
Yeah, I did that just now. I also put gorilla glue on and am letting it sit for a bit. Thanks for your help, I'll pop the next one under a heat gun to loosen it up.
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10018096
https://linustechtips.com/topic/795793-remove-motor-from-fan/#findComment-10018111
