Help: My mouse turns off and on.
Tonny
I have a problem my mouse started to turn on and off whenever i move the cursor it goes off for a sec and then is back on and after a sec it goes off again, i have faced this prob before but it fixed some how and before 30 min ago started doing this  .... am sure that the prob is not the mouse.
Please Help any ideas? It seems to be worse when i game and move the mouse a lot.
Edit: Mobo; Asus Crosshair extreme IV
        Mouse : some cheepo Wired USB optic mouse
Edit2 : When am in game it stops every sec when am not in game it seems to stop a lot less even does not stop for a min.
This started happening to my wireless mouse... Try changing the batteries. If that doesn't fix it, then it's not going to get better.
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
Change the batteries genius...
Maybe you should read the whole post genius... it says usb mouse?
Maybe you should read the post clearly genius... its says usb mouse?
a lot of wireless mouses are usb.
No, I assumed it was an eSATA mouse...
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
It might be the USB port
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
i switched the ports but it is the same thing even worse
I think that might be your USBs
Try it in another computer
it works in other systems any ideas how can i fix this?
Not sure, i thought it might have been your USBs, you could try to re-install drivers
