How do I make the EVGA Geforce GTX 1050Ti FTW's fan spin faster than max?
Solved by Turtlesaurusrex25,
There has to be a better way to cool your graphics card than overvolting the fans. Try adding more case fans or reapplying thermal paste. Also make sure your case fans are optimized for static pressure rather than airflow and that you have balanced static pressure. Besides that, if you saw the video where linus used an 11,000 RPM fan you can see how you really hit the law of diminishing returns.
Featured Topics
msit0910 ·
Posted in New Builds and Planning6 -
FRD ·
Posted in Peripherals11 -
Raginryuu ·
Posted in New Builds and Planning2 -
2
16
6
GeeSharp ·
Posted in Servers, NAS, and Home Lab2
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
