Hi im looking for good but not too expensive AIO for CPU.
Curently Im thinking about -
Corsair H100i V2
ENERMAX Liqmax II 240
And thats pretty much all.
I was thinking about Kraken X41/x61 but they are 140/280 and thats not fit to Fractal Define C at top position (CPU want to TOP),
In future I thinking about NZXT G10 + some AIO but thats gonna go for front so its can be 140/280 that will doesnt matter. But now I need to find something to fit in 120/240 at top for CPU.
Thanks.,
https://linustechtips.com/topic/790977-which-aio-for-cpu-240-max/
Pick which one you think looks best and fits your budget. They will all perform the same within a small margin. The corsair will probably come with quiter stock fans, judging by the higher price. But... Temps will be the same.
H100i v2 is a solid choice. You won't be dissatisfied as it is consistent and installation is very easy.
I would reccommend the Kraken x62 if you could fit it. It is a favorite of mine :(
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
1 minute ago, OsuMasterz said:
While very little have tried this, EVGA recently released their own AIO. The CLC 280 liquid is a 280mm for $99 and has software for RGB and fan control.
He can't fit a 280 in the top of his case. He specifically said it has to be a 240
Read the post before responding.
To add one thing to your comment, Also please check reviews and stuff about the aio you may want to purchase as a bad aio could kill your system :/
Corsair H100i V2
Thanks.,
NZXT Kraken X52 (240mm and awesome RGB circle on pump, best looking AIO)
Corsair H100i V2
Thanks.,
Just wondering what graphics card are you trying to pur this on.
thanks to all.
first of - it has to be 240 because it goes to top. Front will be GPU (980Ti, was discused at other topic).
x52 looks good, but its little expensive.
I can now get literally new H100i V2 for about 80€. Its good ?
It will be quiet at idle ? (load doesnt matter for me that much)
26 minutes ago, mmm273 said:
thanks to all.
Can you tell us why it has to be on top if you're going to get a front mounted one later?
8 minutes ago, mmm273 said:
because at front it will be for GPU.
I found now this - pretty cheap and had Great reviews, what you thinks ? https://www.kitguru.net/components/cooling/dominic-moass/arctic-liquid-freezer-240-aio-cpu-cooler-review/6/
Then just transfer the use of the front from the CPU to the GPU when you get another radiator.
48 minutes ago, mmm273 said:
thanks to all.
if your watercooling gpu with aio, may I recommend the nzxt universal mounting plate which basically allows you to mount any of the supported aios to your gpu and includes fan to blow over stuff like vrm
yeah I know, if you mean G10, thats in plan. But still support for AIO is limited so I dont want to limit it futher to only 120/240 because my CPU will be sitting in front. So i will buy 120/240 AIO for CPU (where Im not limited with any "compatiblity list") and than I can go for GPU what ever I found compatible with G10.
NZXT has the Kraken X52 (240mm).
I'd personally recommend the Corsair H100i V2. Very competitive pricing and will perform within a tight margin as well. It's an Asetek unit, so we all know how those will perform.
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
15 hours ago, mmm273 said:
ok thanks to all, on weekend I will decide between that H100i V2 or that Arctic (which is my favorite now, as I read reviews its quiet and coolest, pretty cheap also)
what bout the fractal design celsius
52 minutes ago, mmm273 said:
looked reviews and cooling performance is pretty bad. AIO as is looks great, but its between aircoolers in OCed performance, so no thanks.
oh, that sucks, tbh I don't care much bout aio's
Good luck on your cooling adventure :)
(also plz remember to select a best answer so people viewing posts know that this has been solved :) )
