I have an alienware 15, the graphics amplifier, a couple of compatible GPUs and bridges so even AMD CF is a go too but i dont have the thunderbolt 3 adapter to test with. Its not a question of bottlenecks, more of addressing multiple GPUs.
There are many things you could consider especially if gaming using the laptop screen. Dx12 can make use of multiple GPUs that arent the same with no SLI/CF needed. So if a game or compute program could make use of multiple GPUs, considering the alienware 15 can have a total of 3 dedicated GPUs, what sort of performance could you expect using a compute program like luxmark or a dx12 game that is made to make use of multiple GPUs?
Not only would that not be possible because of thunderbolt 3, GTX 10 series doesn't support over 2 GPU's in SLI.
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
While SLI may not be possible (dell US has alienware with AMD GPU btw), the other question is how effective would it be at addressing multiple GPUs at once.
If you took luxmark and used all 4 GPUs (intel IGP, onboard nvidia + 2 GPUs) or even dx12 games that can leverage multi GPU without SLI/CF and measure how different the performance would be.
Unless you already have 3 1070s.Sure you can measure the performance but there is literally no practical benefit  and I do not belive it is possible as SLI is not supported over Thunderbolt
My life
i dont have 3 1070s, i do have 2 titans but i lack the thunderbolt 3 adapter for attaching GPUs for it. I still have my old expresscard adapter.
Unless you already have evrey single thing you need.Just don't
My life
First of all, does the eGPU docking you use have more than 2 PCIe slots?
Secondly, in order to give usable bandwidth, does your laptop have 2 thunderbolt 3 connectors?
Desktop benching:
the eGPU docking i had was for expresscard, the adapter itself has multiple cable slots to allow for multiple pcie links but it would be a matter of finding a thunderbolt varant.
The alienware 15 has a thunderbolt 3 connector and a seperate alienware graphics amplifier which is their own proprietary connector for attaching PCIe cards.
You need at least 2 thunderbolt 3 ports
My life
not sure how thats relevant as alienware has both thunderbolt 3 and its own graphics amplifier port which allows for 2 GPUs. I think linus did test both on the alienware when comparing the razor blade with an eGPU and the alienware however he did not test games/programs that could make use of multiple GPUs at the same time and using both the alienware graphics amplifier and thunderbolt 3 at the same time.
The Graphics Amplifer has 1 pci slot how do you put 2 gpus in
Edit:Im worng
You want to spend 900 to also buy a razer core to do this
My life
unfortunately i dont have 800 laying around to see what 3 gtx 1070s can do combined with a 7th gen intel IGP but linus has many things laying around that he could make use of to test. I've already spent on things i needed including high capacity drives and more ram.
So perhaps this could be an idea for one of his videos, packing as much GPU power into a laptop and seeing what it can do in multi GPU software and games.
why has no one mentioned Kaby Lake mobile CPUs literally don't have enough PCIE lanes to do this shit.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
6 hours ago, System Error Message said:
they dont need to, i suspect the internal GPU will be linked down to x8 for both thunderbolt (x4) and alienware graphics adapter (x4).
According to intel ark, you can have Up to 1x16, 2x8, 1x8+2x4
mhm. and i assume the 2  nvme slots on the motherboard are completely useless then, running PCIE 1x0.
TB3 on Alienware's run through the motherboard PCH which is shared with the NVME drives. AGA is dedicated PCIE direct. Internal GPU is directly linked.
This would vastly more difficult than other eGPUs that have known been to run through SLI. (There are cases of eGPU sli, but all of them were done through the same input tb2.). When you have 3 different methods it will literally never work. All have different protocols.
https://www.techinferno.com/index.php?/forums/topic/5751-2013-13-mbp-gtx780ti-sli16gbps-tb2-sonnet-ee-sel-win81-squinks/
^ here's a link to someone sling 2 gpus via the same type of port.
Laptop Main
good link, so it is possible to SLI. This could mean that the GPUs config is 1x8 for the onboard dedicated, 1x8 for alienware graphics amplifier, 1x4 for thunderbolt 3. Alienware US offers AMD GPU as an option so perhaps a triple CF could be done.
Perhaps this can be made even more insane with one of the older nforce PCIe chips to provide more switching for more PCIe slots on the graphics amplifier, chaining 2 GPUs on thunderbolt 3 to allow for a maximum of 6 GPUs, which may not be great for gaming but definitely good for compute with the quad core i7 and dual channel ddr4 being the bottleneck.
