MSI AB reads 95, Card is not hot to touch. Advice?
vESP
i purchased a gtx 550ti in a bundle of dying or dead gpu for 5$ aud.  well this one hits 95c and just sits there. turn off heaven and the card drops rapidly to 50c. then lowers slowly. so can MSI be broken? when i plug the card in to my test bed i get some bios info on the screen before i get any motherboard bio post.
Maybe its running a buggy custom bios ?
how do i go about resetting a bios on gpu?
Faith: WIP
Cpu: intel 6700k
RAM: g.skill ripjaw v 3200mhz 16 18 18 38 2n 32gb 4x8gb
MB: Asrock extreme 7+
GPU: GTX 1080 TI Poseidon Platinum Asus ROG
PSU: Cougar 1050W 80+ gold
Case: IN WIN 509 ROG [ black red ]
Cooling: Barrow Fittings, Block, 360mm x 60mm rad, 18w d5 pump, 210 res, EK blood red premix. Poseidon GPU block
SETUP: BenQ 27" 144hz|BenQ 28" 1080p VA 60HZ|Corsair Strafe RGB|Razer DeathAdDer Chroma|ATH IM70|E10k Olympus 2 amp|DX Racer King
Faith: WIP
Cpu: intel 6700k
Before any of that, have you actually pulled the thing apart and taken a look at it? Is it thermal throttling?
im doing that right now so far its this!  [ i test the card as i get it before i even take it apart for cleaning etc, saves isopol and pastes]
this is what i found, cleaning as i type.
Faith: WIP
Cpu: intel 6700k
Gnarly. Probably hasn't been touched internally since the factory. Cleaning that dust out, and getting some paste that'll actually do something on there should go a long ways towards helping. Sometimes dust alone can cause oddities with hardware.
heres some screenshots the before and after temps of me cleaning this card to brand new standards and using noctua thermal TIM
51 is max load temp after clean
95 is max load and idle temps before
Faith: WIP
Cpu: intel 6700k
51c, nice and chilly. Fairly contrasting what a bit of dust, and old paste can do, eh?
What'd you have planned for it? =p
That reminds me of my GTX 650ti OC 2GB. Long story short, never go without dust filters if you have a uarry or concrete plant within at least a 10km radius.
"We also blind small animals with cosmetics.
We do not sell cosmetics. We just blind animals."
"Please don't mistake us for Equifax. Those fuckers are evil"
This PSA brought to you by Equifacks.
PMSL
yea was from what i can tell a old workstation set for some graphic deign firm. all dust and junk in the fans . im sneezing now and my rag is brown. was light grey
just cleaned its brother so if i can get both to be working maybe try SLI for a laugh and then resell them tbh
Faith: WIP
Cpu: intel 6700k
Update. both cards work. looks like thermal overheating was the issue with both now i have $5 SLI 550 to play with till i get a buyer lol.
Faith: WIP
Cpu: intel 6700k
they sold legit 24 hours after ebay listing. Wow. 5$ cards turned a 95$ profit for me
Faith: WIP
Cpu: intel 6700k
Lol gg sir
