Best ATX case around $100 USD? Bit OCD on looks.
Zando_
I'm going to eventually upgrade my case (currently a Corsair Spec-02). I'm thinking about going for a Corsair 400C (but no TG :(), a Phanteks P400, or an NZXT S340 Elite. I'm not sold on the S340 Elite, bit it is till a nice looking case. I'm hoping to get a 980 Ti and upgrade to Ryzen, and put in a custom loop. Which will look the best with a water-cooling loop, has the best cable management, etc? Are there any other cases with a similar clean look that are better?
I'm most likely getting an ASRock Tiachi mobo, so I'd like the case to look good with that. I like the idea of a white PC, but I don't think it'll match my other devices and such. The only white devices I've had are an old broken iPad 3, and an iPhone 4s and 4. Now I've got a Space grey iPhone 6 Plus and iPad Pro, and a 2012 MacBook Pro (classic silver). I'd like to get a bamboo desk, so it'd go good with white, and my room is light green, so it would make for a nice natural/clean look. Also, my bed and 'extra' desk are a battleship grey. I don't think I have the audacity to pull off the white look.
Also, what color RGB should I go for? I'd like to try a purple glow, but again, that doesn't jive with my personal style or decor. I definitely want to avoid black and red and black and green, as they are overused, IMO.
Thanks for any help you guys can give me!
EDIT: Also forgot to add, and just remembered it because of someone else who wants it, the NZXT H440 also looks nice.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Phanteks Enthoo series are worth a look.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
I have, but aren't they expensive? I think they're around $160 USD.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Some are but i know there are cases in the series for less than 100 dollars.
I've got the Enthoo Evolve TG. The price bump is worth it imo
The P400S with tempered glass is around 100 USD, the plastic window version even cheaper.
Yeah if you're looking at the Enthoo Pro's and stuff, you're looking at 160 USD.
I am personally looking at the P400S as it seems like a great case + it's looks aren't an 'overstatement' (as in it doesn't look super over the top)
I do think that the S340 is a good choice tho, I've built in the standard one before and it was nice
I'm not too sure about a custom loop though, I know the enthoo is good for it
Yes, the Enthoo Evolv would look wicked with a custom loop. But I'd be torn between that and the Corsair 570X.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
How come the S340 isn't a good choice? @Bezolek is torn between an S340 Elite and the H440, so any info would be helpful.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
If it was between them two then I would go with the S340 Elite, it's far less in your face. I suppose that comes down to your preference tho. I always thought that the Corsair Air 540 was a nice looking case, maybe look into that?
That's another case I really like. I like the S340, but I think the Phanteks P400s is a bit softer looking.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
I'm not a fan of the P400's, if I was you I'd spend some time really looking for one, I bought a 760t around 2 years ago and it's my biggest regret. It's just sat their and gathered dust since I bought the Enthoo
how about Phanteks new case, that tower one? Not too sure on the name, not follow computex that close but it looks cool and different
I haven't heard about it. If I was going to get any case from Computex, I'd get the massive Corsair one that can fit two PCs inside it. And then I'd be bankrupt.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
@Mr. Whale @samcool55 @Minibois I've decided, with the help of Mr. Whale, to go for a Phanteks Enthoo Evolv TG. Only prob is, what mobo? High end ASUS mobos are too expensive. I really like the ASRock Tiachi, but I don't know if it's compatible with the RGB in the Evolv. Which leaves me with MSI's mystic light sync. I can afford an MSI Gaming Pro Carbon, and really love the way it looks, but I've kind of been scared off by people saying they have memory OC problems. Is it really as bad as they say?
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
The only info I can give you about the Phanteks cases is the led is compatible with Asus Aura sync and MSI Mystic Lighting. That much I do know as I have 2 P400 cases with complete rgb led setups from Phanteks in them.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
Well, once I get my mobo and CPU, I'll find out, won't I? :D
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
The H440 would be terrible for water cooling because of the small side vents at top that neuter any top mounted radiator. I would completely strike that case from your list.
OK. @Bezolek, this may be the deciding factor you need if you want to do a custom loop at any point.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
