so I have an lga1150 motherboard, and the new cpu I bought is an i7-7700, and the dumbass that I am, didn't look up if I had to get a new motherboard or not. The i7-7700 is LGA 1151. and before I didn't know that, I tried installing the i7-7700 to my lga1150, and realized it didnt worked and saw it had bent corners...
https://linustechtips.com/topic/788433-bent-cpu-corner-help/
I think that CPU is...
Kaboom
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933151
3 minutes ago, Noobie_ said:
Try using tweezers to pull them back straight. But be gentle. Hope its alright!
This is a CPU, it doesn't have pins.
He damaged the CPU not the motherboard.
The PCB is obviously completely bent and ruined, tweezers will literally do nothing to a broken piece of fiberglass.
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933164
Hard to tell from the picture, but CPU may be screwed. RMA it, nothing else you can do.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933168
I don't think the warranty covers stupid people breaking the product, but he could at least try.
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933174
Bend it back. If it doesnt work, RMA. if it does ur golden.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933178
Could lie and say it was damaged in transit :P (Technically it was, transit to the correct socket).
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933179
Just now, rn8686 said:
Could lit and say it was damaged in transit :P
Yes, except this is obviously damage from putting a CPU in an incorrect socket.
You could ship a CPU outside of the box and it would probably be in better condition than this, that's how strong the PCB is.
Maybe say he bought it used and it isn't working? Pretend like he's some old woman who has no idea about computers? :P
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933185
Could try to bend it back, but you're probably fucked.
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933190
You could try to carefully bend it back, but its probably dead. At least OP can make the most expensive key ring tag.
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933207
Don't bend it back. RMA. It happens. I've had a friend do it, got a new CPU back. Then had me install his gear.
RMA, don't bend back. You'll break the PCB, and have to buy a new chip with no chance of RMA.
Also, it's call ZIF Arm, for Zero Insertion Force Arm. You had to have out more than Zero foot-pounds of force behind that.
https://linustechtips.com/topic/788433-bent-cpu-corner-help/#findComment-9933234
