Combining Ethernet and Wifi
Go to solution Solved by Beowulff83,
1 minute ago, RageNuke said:
You think the jitter and latency will be close enough for it to not matter?
Shouldn't if you have a good signal and your cable and router are working as should,  its not Ethernet for sure but it should work well.
Hello everyone,
I recently moved and got a 150 Mbps download package. I have a 2.4GHz PCI-E wireless adapter on my computer that I bought as a back up and never use, since before I moved I connected by ethernet through a powerline adapter. In my old house I had a 50 Mbps package and the powerline worked perfectly. Now, in my new house, I'm only getting about 35-45 Mbps, even though I have a much better internet plan. I think this is just because the wiring in the house just isn't as good over here, especially in my room. I can't just run an ethernet cable directly, so I ordered a 5GHz dongle so that I can get full advantage of my speed on my desktop. I still have the powerline adapters though, and I game a lot. So I was wondering if there was any way to use the ping that I get from the powerline and the speed from wireless at the same time. Can I combine both connections or somehow separate them so that games and VOIP use ethernet and media and other downloads use wireless? Thanks for the help.
https://linustechtips.com/topic/788058-combining-ethernet-and-wifi/
If you are getting a decent 5g signal where your pc sits I would just use that.  I am not a fan of powerline adapters, they work in a pinch but too much going on for them to be a reliable connection.  I do not know of a way for you to combine the two either.  If your cable and modem/router is operating as it should the 5g connection should be pretty close to an Ethernet connection.
Im confused, so are you currently using Wifi and getting 35-45Mbps?
Whats your connect rate using Powerline?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
I'm getting 35-45 using the powerline about the same on WiFi since the adapter is only 2.4GHz. I order a new 5GHz adapter, though.
4 minutes ago, RageNuke said:
I don't want to combine them to increase speed. Just have it so that any big files download through WiFi and games use Ethernet.
its a pain to do, no reason though, wifi is fast enough to no limit you.
If theyre about the same, then just use the Wifi - most wifi is pretty decent these days, especially if your new 5Ghz adapter and AP support 802.11AC (Wireless AC) which is a low latency and fast wireless spec.
I'm pretty sure I have this gateway: https://www.xfinity.com/support/internet/wireless-gateway-3/. Not sure if I have the version 2 or 3, but it's probably version 3 since it was installed today. The page says it operates with the 802.11AC spectrum and I checked the router settings and it is setup that way. This is the adapter I ordered: https://www.amazon.com/gp/product/B018TX8IDA/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1. So technically I should have the best/a really good connection? I have never actually had 5GHz before so I don't know how good they are just yet.
yes, you should be good, your limiting factor will be how far your pc sits from the router and the obstacles in between the two.  5G is faster and more reliable but the trade off is the signal doesn't travel as far
Just saying game doesn't require that much bandwidth also with VoIP, as long as you have stable and low ping connection such as power line adapter or 5gz wifi you should be solid.
Magical Pineapples
Ok, if there's no way, then I'll see on Monday if the connection is reliable enough. Right now I'm getting 124 Mbps on my phone on the 5GHz network. If we drew a line from the gateway to my pc there would be three walls in between, but the distance is only about 10 meters. So it's probably a pretty ok connection. Thanks for the help.
I hope that WIFI adapter works well for you, but I'm skeptical about the quality of it.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
