How much can i sell my build for?
I'm planning to upgrade/sell my PC. Specs:
Cpu: fx8350
Cpu cooler: hyper 212 evo
Gpu: msi r9 290x 4gb
Mobo: msi 970 gaming
Ram: 1*8gb ddr3 corsair vengeance 2400mhz
Psu: corsair vs650
Case: generic ATX + 6  arctic f12 silent fans
should i fully sell it? Upgrade some components? and which ones?
You should upgrade the CPU first.
Don't forget to "Quote" when replying so we can see it.
so that means selling the cpu/mobo/ram to switch over to ryzen or intel with ddr4
pretty much
1$ paypal
1st bid
Pc Specs
CPU: I7 6700k 4.5Ghz  Motherboard: Asus Z170-A Ram: Corsair Vengeance 16GB DDR4  Cpu Cooler: Corsair H100i v2  Storage: Crucial MX300 525GB/Hitachi Deskstar 3TB  Graphics Card: GTX 1080 Founders Edition Case: Corsair 750D Power Supply: EVGA SuperNOVA 850w Keyboard: Corsair k70 Mouse: rival 300
so that mean selling the cpu/mobo/ram to switch over to ryzen or intel with ddr4
$400 max
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
Cpu: fx8350
Psu: corsair vs650
well, If you can't get at least $250 you aren't trying, if you want a quick sale maybe conside about 250, if you have a while and want as much as possible consider parting it out,
Yours faithfully
The R5 1600 already comes with a decent cooler, just wanted to mention this. And get a good PSU, I would recommend the Seasonic S12 II.
You could check out the RX 580.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
just upgrade cpu and mobo, the 290x is still a beast.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
IF you have a 290x already that 980 will dissapoint if u want to upgrade, its like only 5 fps more. Same with the rx 580, you will probably get like 10 fps at most. I would recommend changing that PSU too in your pcpartpicker, and if u want upgrade from your current build, get at least a 1070 on the GPU side. If I were you just sell your current mobo cpu ram and use that cash for ryzen build and save up for GPU later on
33 minutes ago, will2135 said:
1$ paypal
1st bid
you have been out bid
$2.00
The thread was moved to the New Builds & Planning section
If you need help with your forum account, please use the Forum Support form !
