I have this dream of making a very powerful mATX PC, with a 8-10c CPU and a top of the line GPU.
The smaller the PSU is the better.
So what are the specs of such a PC going to be?
2x normal SATA SSD's
1x NVMe SSD
1x HDD
3x-4 120mm fans
2x 92mm fans (NF-A9x14)
1x 240mm AIO
1x 1955 or r7 1700 (depends on motherboards)
32gb of ram
1x 1080ti or whatever AMD will have
This will be in a Modded Styx with front intake (hence 2x 92mm), the smaller the PSU is the better it will all fit together. I was personally thinking a silverstone ST85F-PT, my current PC has a AX860i, but sadly it is a bit too long to fit in the Styx case unless I get a short GPU and by short I mean 280mm or less.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/787438-psu-for-small-powerful-pc/
Maybe the: Corsair SF600
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
I don't think that is going to have enough power for this system if I OC my CPU and GPU. I am going to put my system under close to 100% load from time to time with 3D modeling.
EVGA G3 750 will come in a SFF format soon, id go for that
Builds:
It will.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
The Test
For our review of the GTX 1080 Ti, we’re using NVIDIA’s 378.78 driver.
CPU: Intel Core i7-4960X @ 4.2GHz
Motherboard: ASRock Fatal1ty X79 Professional
Just now, JDE said:
It will.
Just now, deXxterlab97 said:
The Test
1
Well, when I use those PSU calculators they say the system is going to use about 620-630w under full load.
I don't know the full setup of that test, I am going to run quite a few fans and quite a few hard drives, which are going to draw more power.
I can see that a 4960x draws about 210w under load and I expect the 1955 to do the same (just with 10c instead of 6c :D)
that seems nice, really nice. Do we know any info about the size?
well its probably SFX for the formfactor but it looked a bit too long for that in the video i saw. dont think we have actiual numbers yet but i think release date is pretty soon
Builds:
NEVER EVER use PSU calculator, they overrestimate things by a lot
Hard Drive shouldn't consume that more power, a decent 600w is ffine
New G3 is a SFF size (small form factor)
Well it is better than nothing :D I can't really use my current system as a test for how much it is going to draw, since that is a 4770k running base clock, because anything above that and it becomes insanely unstable and a HD 7950 + 6x120mm fans + 3x sata SSD + 1x HDD. It peaks at about 340w, but the power hungry parts will be a lot more power hungry in my next PC....
As far as I can see a SFF is about 125mm long.
SFF is as small as you can go in terms of good PSU. Again 600w would be fine, but if you are really that concerned for wattage then the next PSU you can get is a 700w Silverstone Platinum certified PSU https://www.amazon.com/dp/B01G26SMTQ/?tag=pcpapi-20
https://pcpartpicker.com/products/power-supply/#t=10&sort=-watts&page=1
ehh 130mm, only a single 1cm smaller than the 850w ATX one and 150w less, but it is slimmer, which might be very nice and maybe give some extra clearance. the SX800-LTI is quite interesting it is also 130mm, but 800w, then again it cost quite a bit more.
Think I am going to look out for the new 750w G3 to see if they can make it 125mm or shorter.
Thanks
PSU calculators are random number generators and often have monetary incentive to exaggerate power demands of the specs of the system input (IE the Cooler Master calculator).
600W is plenty for a 1080 Ti system.
