id get an RX 570 over the 1050TI here, dont know how hard OW is to get to 144fps tbh
Builds:
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911018
I'd go for an RX570, and maybe upgrade the CPU later on.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911019
You know you can get windows for 20 dollars a kinguin.net or other sites?
And do you have a 144hz monitor otherwise your 144fps isnt worth it if you have 60hz :)
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911037
You could search for 1TB HDDs. I think you could find some in the same price range as the 500GB one listed in your build. And check out some RX 570s.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911043
ive seen a couple videos and benchmarks and apparently nvidia cards run better on overwatch + i like shadow play alot, but i will look for some 1tb HDD around same price hopefully i find one
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911049
9 minutes ago, wiejfowiefwf said:
https://pcpartpicker.com/list/VhxFnn
Will this run Overwatch at an average 144 fps with settings on low-medium ?
Are there better parts i could be using?
Can you add $20 for the PSU in my signature?
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911062
Just now, WereCat said:
not true
How does it work then? hz is a refresh rate and fps too. If your monitor refreshes 60 times per second and you have 144fps you still get 60fps right? Correct me if im wrong :)
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911066
You'll still get better results, just won't be as impressive.  It means you'll have better frametimes
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911073
2 minutes ago, wiejfowiefwf said:
which version do i get theres alot and im kind of a noob to pc building
Probably the cheapest. There is not a big difference
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911082
Yes, but there are more benefits to higher refresh rate.
More FPS -> Better frame time -> lower input lag -> feels more snappy and responsive
The lower the frame time the better, obviously there are diminishing returns and is hard to tell difference after a certain point but it will always be a benefit no matter how well you perceive it.
Consistency is the key. If the frame time is very low that is great but sometimes there may be some spike which may cause latency spike or visible stutter and that is not good. This happens less frequently or is usually eliminated on very high frame rates, that said, it can still occur in some scenarios.
For example, you get 60FPS, but all the 60 frames were rendered in 0.5s, in the other 0.5s the image was stuck on one frame which you will definitely notice.
If it was 60FPS consistently divided across 1s then it would be a very smooth experience, even more so if each of the rendered frames were extremely close or synced with the refresh cycle of the monitor.
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911092
well whats a cpu thats a step up but not too expensive that the pentium g4560
3 minutes ago, elpiop said:
you would benefit more from upgrading the CPU rather than the GPU for overwatch
The pentium has good IPC and decent clock, not much to upgrade to in this price bracket.  @wiejfowiefwf Get windows 10 from reddit or kinguin and this much better build is way under $600
PCPartPicker part list: https://pcpartpicker.com/list/DXYHtJ
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($62.50 @ B&H)
Motherboard: MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard  ($62.88 @ OutletPC)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($54.99 @ Newegg)
Storage: Sandisk - SSD PLUS 120GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Storage: Seagate - Barracuda ES 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ Amazon)
Video Card: Sapphire - Radeon RX 570 4GB PULSE Video Card  ($182.99 @ SuperBiiz)
Case: Fractal Design - Core 1100 MicroATX Mini Tower Case  ($28.99 @ SuperBiiz)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($56.99 @ SuperBiiz)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($92.99 @ Amazon)
Total: $646.31
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911095
Total: $646.31
ok i went with this build and ill buy windows from kinguin, thanks for the help
i got one more question though, does 1 stick of ram vs 2 stick of ram make any difference?
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911137
Not particularly
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911145
Dont get the power supply from that build, its the same quality as the one you put in your original build, not worth the extra cost.
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911159
are you sure the original one has enough wattage? pcpartpicker is telling me the build is 329W and im just scared of having a psu that cant handle it
https://linustechtips.com/topic/786576-need-opinions/#findComment-9911178
