CSS/HTML HELP
Go to solution Solved by zwirek2201,
4 hours ago, bomberblyat said:
<!DOCTYPE html>
<html>
<head>
<title>tht12</title>
<style>
	body {
		width: 900px;
		background-color: #F1D01F;
	.header {
		margin-left: 450px;
	.kuva {
		position: relative;
		display: block;
	#menu {
		height: 40px;
		background-color: green;
		margin-left: 450px;
		position: absolute;
		text-align: center;
		width: 900px;
	h2 {
		color: black;
		margin-left: -400px;
		left: 500px;
		bottom: 20px;
		position: relative;
	.p {
		color: black;
		text-align:left;
		margin-left:500px;
		margin-right:-500px;
		margin-top: 0px;
		font-family: sans-serif;
	#maintable {
		width: 900px;
		margin-left: 450px;
	tablecell {
		width: 400px;
	nav {
		color: #FFFFF;
		list-style: none;
		text-align: center;
		padding: 20px 0 20px 0;
.nav > li {
		display: inline-block;
		padding: 0 25px 0 25p;
.nav > li > a {
		color; #FFFFF
		text-decoration: none;
</style>
</head>
<body>
<table id="maintable" border>
  <tr>
    <div class="header">
    <div class="image">
    <img src="kevat.jpg">
	<th></th>
	</div>
	</div>
	</tr>
	<tr>
	<nav>
	<a href="#">Kevät</a></h2>
	<a href="#">Kesä</a></h2>
	<a href="#">Syksy</a></h2>
	<a href="#">Talvi</a></h2>
	</nav>
	</tr>
	<tr>
	<td class="tablecell"><h2 class="h2">Kevät</td>
	<td></td>
	</tr>
</table>
</body>
</html>
well this is my last one from today atleast i have next time time to finish this so i could really use some help, i know there is - things but i dont know any else solution at the moment, excuse me for distraction :)
I will not be able to help you with this one because I'm really busy with my work.
On top of that I advised you to not use negative values for margins which you did not do, to only enclose the margin in the table which you did not do and to not center the content using margins which you also did not do. I tried helping you with the project/homework, but at this point it is just me writing some code for you. Also, your code has multiple syntax errors (including unclosed tags, hex colors with only 5 characters in the value, misused brackets etc.) and on top of that you are starting to use stuff that you really don't need (like child selectors) which only complicates your code. This is really not a difficult webpage and at this point you should easily be able to do it.
My last advice:
1. Image
2. Table with menu buttons
3. Header
4. Text
Do not put image or text in the table, only menu buttons.
Read all of the posts again because they contain solutions for every problem that you're having.
On 23.5.2017 at 5:06 PM, zwirek2201 said:
No problem ;) glad to help
we meet once again xD so i have to  do page like this
https://gyazo.com/3899dfa6e36d9752f934a2eab694b5cb but i dont know how  do i add that background image, thanks once again xD
<html>
  <head>
    <style>
	body {
			width: 960px;
			background-color: black;
	.header {
			background-image: url (/tht11/aurinkokunta.jpg);
	h2 {
		color: yellow;
    </style>
  </head>
  <body>
  <table>
  <tr>
    <th colspan="2"></th>
  </tr>
  <tr>
    <td id="header"> <h2 class="h2">Aurinkokunta</h2></td>
    <td></td>
  </tr>
  <tr>
    <td></td>
    <td></td>
  </tr>
</table>
</body>
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9882640
<html>
  <head>
    <style>
	body {
			width: 960px;
	.header {
	h2 {
		color: yellow;
    </style>
  </head>
  <body>
  <table>
  <tr>
  </tr>
  <tr>
    <td></td>
  </tr>
  <tr>
    <td></td>
    <td></td>
  </tr>
</table>
</body>
Hello there ;)
Two things:
- If you want an image to be a background image of your website, place it in the body tag. It will be under all of the elements of the page.
- In the background-image tag, your path to the image file should be enclosed in quotation marks
Your code should look something like this:
body {
  width: 960px;
  background-image: url ("/tht11/aurinkokunta.jpg");
Also, your picture is likely going to be repeated over and over again until it reaches the end of the page. You probably want your image to fill the whole width of the page, so it should not repeat itself horizontally. If you want your background image to repeat vertically, you can set background-repeat property to y-repeat (it will only repeat itself vertically) or no-repeat (it will not repeat itself in any direction). Here's an example with no-repeat:
body {
  width: 960px;
  background-repeat: no-repeat;
/*background-repeat: y-repeat;     If you want it to repeat vertically */
Also, your image is going to be positioned on the left edge of the body, so you have to position it at the top of the page (it is going to center it automatically) like so:
body {
  width: 960px;
  background-position: top;
If your background-image is wider or narrower than the 960 pixels, you have to change its size using:
body {
  width: 960px;
  background-size: 960px auto;
The first value in background-size is width, the second is height. Since you don't want to set specific height because it would affect image's aspect ratio, you can set it to auto and it will sort itself out.
Also, I've noticed that you have problems with CSS classes and ids. Let me explain:
Id and class have almost the same role. They are CSS selectors and allow you to specify visual properties of elements of your website. The main difference between an id and a class is that id can be used to identify only one element of page. Classes can be used multiple times in one page.
You can use Id to specify properties of a big element of your page that you know is going to appear only once on the page (such as top section or footer). Classes are used for elements that are used multiple times on one page (like buttons, paragraphs, headers etc.)
The difference is small, but important:
#myId {
/* This is an Id */
.myClass {
/* This is a Class */
and in html:
<div id="myId">
</div>
<div class="myClass">
</div>
If you create a class (like you did with header class), but try to reference it in html using id selector, it is not going to work. If you want to read more about Ids and Classes, this article is pretty good:
Class and ID Selectors
Hope it helps ;)
Try, fail, learn, repeat...
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9882815
13 minutes ago, zwirek2201 said:
Hello there ;)
Two things:
body {
  width: 960px;
body {
  width: 960px;
body {
  width: 960px;
body {
  width: 960px;
#myId {
/* This is an Id */
.myClass {
and in html:
<div id="myId">
</div>
</div>
Hope it helps ;)
<html>
  <head>
    <style>
	body {
			width: 960px;
	#headerlogo
			background-position: ;
			I DONT KNOW WHY THAT div class="header" doesnt work
                  (im sorry im so confused i started css yesterday these all divs and class etc things makes me crazy and its hard to understand english guides about them :/ but that what u have understanded is kinda like this div id= constructive div class = style, ill try read that your linked thing im saying this again im really thankful to you !
	.header
			font-family: arial;
	h2 {
		color: yellow;
    </style>
  </head>
  <body>
  <table>
  <tr>
  </tr>
  <tr>
  <div id="headerlogo">
    <td> <img src="aurinkokunta.jpg" alt="aurinkokunta.jpg"><h2 class="h2">Aurinkokunta</h2></td>
	</div>
	</div>
    <td></td>
  </tr>
  <tr>
    <td></td>
    <td></td>
  </tr>
</table>
</body>
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9882887
4 minutes ago, bomberblyat said:
<html>
  <head>
    <style>
	body {
			width: 960px;
	#headerlogo
	.header
			font-family: arial;
	h2 {
		color: yellow;
    </style>
  </head>
  <body>
  <table>
  <tr>
  </tr>
  <tr>
	</div>
	</div>
    <td></td>
  </tr>
  <tr>
    <td></td>
    <td></td>
  </tr>
</table>
</body>
I don't know exactly what you're trying to achieve using divs. Div is just a container that holds some different elements. When it comes to Ids and classes, I would just recommend you were using classes for everything. There is no difference between id and a class and it makes things more confusing.
I cleaned your code from everything that was broken or weird. Please copy the code I'm posting on your machine and use it to go further. It's going to make everything easier.
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
      background-image: url("/tht11/aurinkokunta.jpg");
    h2 {
      color: yellow;
    .header {
      font-family: arial;
      text-align:center;
  </style>
</head>
<body>
    <h2>Aurinkokunta</h2>
  </div>
</body>
In the code you have a background image that should have correct width and should be placed in the center of the body and your header with a yellow title. Based on what you sent in the screenshot, you need to create a table with two columns and some text.
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9882980
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
    h2 {
      color: yellow;
    .header {
      font-family: arial;
      text-align:center;
  </style>
</head>
<body>
  </div>
</body>
okay this is my last question for you today so you dont need to use your alltime to me, is this going correct? and how do i place the text to center of image like on the picture
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
    h2 {
      color: yellow;
    .header {
      font-family: arial;
      text-align:center;
  </style>
</head>
<body>
<table>
  <tr>
  </tr>
  <tr>
    <td> <div class="header">
    <h2>Aurinkokunta</h2> <img src="aurinkokunta.jpg"></td>
	</div>
    <td></td>
  </tr>
  <tr>
    <td></td>
    <td></td>
  </tr>
</table>
</body>
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9883043
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
    h2 {
      color: yellow;
    .header {
      font-family: arial;
      text-align:center;
  </style>
</head>
<body>
<table>
  <tr>
  </tr>
  <tr>
	</div>
    <td></td>
  </tr>
  <tr>
    <td></td>
    <td></td>
  </tr>
</table>
</body>
Should work now ;) I hope this is what you needed.
<html>
  <head>
    <style>
      body {
        width: 960px;
        text-align:center;
      .header {
        position: relative;
        text-align: center;
      .image{
        position: relative;
        display: block;
      .text{
        position: absolute;
        top: 0; right: 0;
        bottom: 0; left: 0;
        text-align: center;
        vertical-align:middle;
      .text h2 {
        color: yellow;
        display: inline-table;
    </style>
  </head>
  <body>
    <table>
      <tr>
      </tr>
      <tr>
        <td>
            <div class="image">
              <div class="text">
              </div>
            </div>
          </div>
        </td>
        <td></td>
      </tr>
      <tr>
        <td></td>
        <td></td>
      </tr>
    </table>
  </body>
</html>
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9883742
<html>
  <head>
    <style>
      body {
        width: 960px;
        text-align:center;
      .header {
        position: relative;
        text-align: center;
      .image{
        position: relative;
        display: block;
      .text{
        position: absolute;
        top: 0; right: 0;
        bottom: 0; left: 0;
        text-align: center;
      .text h2 {
        color: yellow;
    </style>
  </head>
  <body>
    <table>
      <tr>
      </tr>
      <tr>
        <td>
            <div class="image">
              <div class="text">
              </div>
            </div>
          </div>
        </td>
        <td></td>
      </tr>
      <tr>
        <td></td>
        <td></td>
      </tr>
    </table>
  </body>
</html>
<html>
  <head>
    <style>
      body {
				width: 960px;
				text-align:center;
      .header {
				position: relative;
				text-align: center;
				margin-left: 200px;
      .image{
				position: relative;
				display: block;
      .text{
				position: absolute;
				top: 0; right: 0;
				bottom: 0; left: 0;
				text-align: center;
      .text h2 {
				color: yellow;
	  .p {
				color: black;
				margin-left: 200px;
				margin-top: -70px;
		.tablecell {
				background-color: white;
				vertical-align: middle;
				position: relative;
		h2 {
				color: black;
				margin-left: 50px;
				width: 10;
				top: 200px;
		h1 {
				color:yellow;
			.tablecell2 {
					width: 200px;
					height: 200px;
    </style>
  </head>
  <body border="1">
    <table>
      <tr>
      </tr>
      <tr>
        <td>
            <div class="image">
              <div class="text">
                <h1>Aurinkokunta</h1>
              </div>
            </div>
          </div>
        </td>
      <td></td>
      </tr>
      <tr>
		<p class="p">Aurinkokunta on Auringon ja kaikkien aurinkoa kiertävien kappaleiden, kuten planeettojen, kuiden, meteoroidien,<br> komeettojen sekä pikkuplaneettojen, kuten asteroidien ja transneptunisten kohteiden muodostama järjestelmä. <br>Pyöreitä pikkuplaneettoja kutsutaan kääpiöplaneetoiksi.<br>
		<br>
		Aurinkokuntamme planeetat ovat Auringosta poispäin lukien Merkurius, Venus, Maa, Mars, Jupiter, Saturnus,<br> Uranus ja Neptunus. Aikaisemmin planeettoihin kuulunut Pluto luokiteltiin kääpiöplaneetaksi ja plutoidiksi<br> 2000-vuosikymmenen loppupuolella. Pluton kohtalo ei ole ainutlaatuinen sillä myös ensimmäisina löydetyt<br> asteroidit Ceres, Pallas, Juno ja Vesta luettiin 1800-luvun alussa planeettojen joukkoon. Aurinkokunnan iäksi on<br> saatu noin 4,6 miljardia vuotta. Myös muilla tähdillä on havaittu omia eksoplaneettojen muodostamia<br> planeettakuntia.
		</td>
			 <th class="tablecell2">
            <a href="Etusivu.html"><h2 class="h2">Etusivu</h2></a>
            <a href="kokojasijainti.html"><h2 class="h2">Koko ja sijainti</h2></a>
            <a href="ihminen.html"><h2 class="h2">Planeetat</h2></a>
            <a href="palaute.html"><h2 class="h2">Historia</h2></a>'
			</th>
      </tr>
    </table>
  </body>
</html>
im doing something wrong with columns
example of what it should look like
https://gyazo.com/ba73250cae8ecc46c4df07f7f2131fdf
i think im getting bit better on css xD but still alot to learn, i promise you instantly see alot errors on my code xD
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9885943
The biggest issue that you're having is that you're setting negative margins. You should NEVER set negative margin unless there is no other way to get something to work. Your text was not positioned properly because of negative margins. Another problem in your paragraph was that you were setting line breaks on your own. HTML will do line breaks automatically for you so you don't have to do it. Below working code. Please compare your code and my code to see what and why I changed something :)
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image{
      position: relative;
      display: block;
    .text{
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position: relative;
    .h2 {
      color: black;
      text-align:left;
      margin-left:10px;
      vertical-align:top;
      font-size:20px;
      margin-top:5px;
      margin-bottom:0px;
    h1 {
      color:yellow;
    a {
      color:black;
      text-decoration:none;
    .tablecell2 {
      width: 200px;
      vertical-align:top;
      padding-top:10px;
         </style>
</head>
<body border="1">
  <table>
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
        <p class="p">Aurinkokunta on Auringon ja kaikkien aurinkoa   kiertävien kappaleiden, kuten planeettojen, kuiden, meteoroidien, komeettojen sekä pikkuplaneettojen, kuten asteroidien ja transneptunisten kohteiden muodostama järjestelmä. Pyöreitä pikkuplaneettoja kutsutaan kääpiöplaneetoiksi.
          <br><br>
          Aurinkokuntamme planeetat ovat Auringosta poispäin lukien Merkurius, Venus, Maa, Mars, Jupiter, Saturnus, Uranus ja Neptunus. Aikaisemmin planeettoihin kuulunut Pluto luokiteltiin kääpiöplaneetaksi ja plutoidiksi 2000-vuosikymmenen loppupuolella. Pluton kohtalo ei ole ainutlaatuinen sillä myös ensimmäisina löydetyt asteroidit Ceres, Pallas, Juno ja Vesta luettiin 1800-luvun alussa planeettojen joukkoon. Aurinkokunnan iäksi on saatu noin 4,6 miljardia vuotta. Myös muilla tähdillä on havaittu omia eksoplaneettojen muodostamia planeettakuntia.
        </p>
      </td>
      <td class="tablecell2">
      </td>
    </tr>
  </table>
</body>
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886083
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image{
      position: relative;
      display: block;
    .text{
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position: relative;
    .h2 {
      color: black;
      text-align:left;
      margin-left:10px;
      vertical-align:top;
      font-size:20px;
      margin-top:5px;
      margin-bottom:0px;
    h1 {
      color:yellow;
    a {
      color:black;
    .tablecell2 {
      width: 200px;
      vertical-align:top;
      padding-top:10px;
         </style>
</head>
<body border="1">
  <table>
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
          <br><br>
        </p>
      </td>
      </td>
    </tr>
  </table>
</body>
oh i see ^^ thank you once again my friend !
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886136
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image{
      position: relative;
      display: block;
    .text{
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position: relative;
    .h2 {
      color: black;
      text-align:left;
      margin-left:10px;
      vertical-align:top;
      font-size:20px;
      margin-top:5px;
      margin-bottom:0px;
    h1 {
      color:yellow;
    a {
      color:black;
    .tablecell2 {
      width: 200px;
      vertical-align:top;
      padding-top:10px;
         </style>
</head>
<body border="1">
  <table>
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
          <br><br>
        </p>
      </td>
      </td>
    </tr>
  </table>
</body>
and by the way how do i size the colum to be under image not to go over like the white part?? width or height doesnt work
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886241
I don't really understand what you mean. Could you provide a screenshot with more information? Which column do you want to resize and what image do you mean?
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886263
Just a thought... you probably shouldn't be doing his homework for him.  He won't learn if you're giving him the answers, because even though you're explaining things he obviously isn't really reading (or at least not understanding) the concepts you're explaining.  One of the most important skills for any aspiring software developer is the ability to quickly learn how to do new things and to be able to solve problems without assistance.  CSS is one of the most basic aspects of web development and there are numerous resources (W3Schools) with in-browser tutorials available.
As for classes vs IDs, unless I missed it I don't think you ever really explained why/when you'd use each.
OP:
A CSS class (.myClass) is for when you have one or more elements that you want to have consistent styles throughout a website.  You create a class in order to re-use the code so that you don't have to duplicate it, because that makes it much harder to manage later when you have to modify it and have the same code in several locations.  Example: you have a basic style for a grid with alternating row colors, font, header, etc that will be used multiple pages.  You can then create a class such as .grid-default and simply assign the class to each grid.
An ID (#myGrid) is for when you have a one-off situation where you need to make style changes to a single control.  For example, say you have one particular grid where you need to add special styles that aren't included in your .grid-default class and you KNOW that you won't be adding those styles to anything else.  You would then create them using the ID so that they don't affect the other grids.  Alternatively, if you are diligent with the order in your CSS file you can use IDs to override class settings... but I don't recommend doing that as it makes reading the code (and therefore maintenance) harder.
Also...
This:
  <div class="image">
    <div class="text">
    </div>
  </div>
</div>
Can be written like this:
<div class="header image">
  <div class="text">
  </div>
</div>
There is no reason for the extra div, you can assign multiple classes to one element by separating them with spaces.
For that matter, your classes there are redundant...
This:
.header
  position: relative;
  text-align: center;
  margin-left: 200px;
.image
  position: relative;
  display: block;
.header-image
  position: relative;
  text-align: center;
  margin-left: 200px;
  display: block;
When you design classes you want as few lines of code as possible, so combine things whenever possible.  If you find later that there is a need for another div or a separate class then you can always break those out, but once you end up with several dozen unnecessary classes or elements it is MUCH harder to refactor and consolidate.  Especially when you have deadlines or multiple people working on the same application.  Get in good habits now or you're going to have a hard time managing your code later.
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886525
OP:
Also...
This:
  <div class="image">
    <div class="text">
    </div>
  </div>
</div>
  <div class="text">
  </div>
</div>
This:
.header
  position: relative;
  text-align: center;
  margin-left: 200px;
.image
  position: relative;
  display: block;
.header-image
  position: relative;
  text-align: center;
  margin-left: 200px;
  display: block;
ookay, thanks
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886594
https://gyazo.com/f3a6bb5eddfc385ba5606b6c5fb340ed
ps. sorry for late response
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886615
OP:
Also...
This:
  <div class="image">
    <div class="text">
    </div>
  </div>
</div>
  <div class="text">
  </div>
</div>
This:
.header
  position: relative;
  text-align: center;
  margin-left: 200px;
.image
  position: relative;
  display: block;
.header-image
  position: relative;
  text-align: center;
  margin-left: 200px;
  display: block;
I like to believe that he is honest enough to understand that he will not learn if he just copy pastes my code. I would like to tell him what he's doing wrong, but on forum this kind of "conversation" could take hundreds of posts. If he doesn't look at my code and his code and tries to understand what I changed and why I did it then he obviously will not learn, but that one is on him ;)
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886643
i have saved every copy of these codes made by me and you and i have looked what i have done wrong etc coz its really useful for me ^^
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886649
26 minutes ago, bomberblyat said:
At the moment I don't know how to fix that. There is some kind of problem with aligning the whole page, but I don't know at the moment. I will try to help you in a couple of hours if I can ;)
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9886743
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image{
      position: relative;
      display: block;
    .text{
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position: relative;
	  float: left;
	  margin-left: 190px;
    .h2 {
      color: black;
      text-align:left;
      margin-left:0px;
      vertical-align:top;
      font-size:20px;
      margin-top:5px;
      margin-bottom:0px;
	  margin-left: 00px
    h1 {
      color:yellow;
	  margin-left:20px;
      vertical-align:top;
      font-size:50px;
      margin-top:150px;
      margin-bottom:0px;
    a {
      color:black;
    .tablecell2 {
      width: 144px;
	  height: 170px
      vertical-align:top;
      padding-top:90px;
	  float: right;
         </style>
</head>
<body>
  <table>
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
        <p class="p">Aurinkokunta on Auringon ja kaikkien aurinkoa   kiertävien kappaleiden, kuten planeettojen, kuiden, meteoroidien,<br> komeettojen sekä pikkuplaneettojen, kuten asteroidien ja transneptunisten kohteiden muodostama järjestelmä.<br> Pyöreitä pikkuplaneettoja kutsutaan kääpiöplaneetoiksi.
          <br><br>
          Aurinkokuntamme planeetat ovat Auringosta poispäin lukien Merkurius, Venus, Maa, Mars, Jupiter, Saturnus,<br> Uranus ja Neptunus. Aikaisemmin planeettoihin kuulunut Pluto luokiteltiin kääpiöplaneetaksi ja plutoidiksi<br> 2000-vuosikymmenen loppupuolella. Pluton kohtalo ei ole ainutlaatuinen sillä myös ensimmäisina löydetyt <br>asteroidit Ceres, Pallas, Juno ja Vesta luettiin 1800-luvun alussa planeettojen joukkoon. Aurinkokunnan iäksi on<br> saatu noin 4,6 miljardia vuotta. Myös muilla tähdillä on havaittu omia eksoplaneettojen muodostamia planeettakuntia.
        </p>
      </td>
      </td>
    </tr>
  </table>
</body>
i fixed it ! :o but now only problem is those h2 text placement
example pic : https://gyazo.com/0799ddabc7638c93ced5ac3fb2966ab8
and rest of page i trust i can do alone ! ^^
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9890903
27 minutes ago, bomberblyat said:
<head>
  <style>
    body {
      width: 960px;
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image{
      position: relative;
      display: block;
    .text{
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position: relative;
	  float: left;
	  margin-left: 190px;
    .h2 {
      color: black;
      text-align:left;
      margin-left:0px;
      vertical-align:top;
      font-size:20px;
      margin-top:5px;
      margin-bottom:0px;
	  margin-left: 00px
    h1 {
      color:yellow;
	  margin-left:20px;
      vertical-align:top;
      font-size:50px;
      margin-top:150px;
      margin-bottom:0px;
    a {
      color:black;
    .tablecell2 {
      width: 144px;
	  height: 170px
      vertical-align:top;
      padding-top:90px;
	  float: right;
         </style>
</head>
<body>
  <table>
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
          <br><br>
        </p>
      </td>
      </td>
    </tr>
  </table>
</body>
Hi!
While you did kind of fix it, you just set the left margin of the table to 190px so it looked like it was centered, but if you changed your display size, it would be off center. I fixed it though (it turned out to be the width of the body that was causing it to be off center).
I fixed the h2 placements as well so now the table looks like on the screen shot.
<head>
  <style>
    body {
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image {
      position: relative;
      display: block;
    .table {
      width:960px;
      margin: 0 auto;
      border-spacing:0px;
    .text {
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position:relative;
    .h2 {
      color: black;
      text-align:left;
      font-size:20px;
      margin:5px;
    h1 {
      color:yellow;
      margin-left:20px;
      vertical-align:top;
      font-size:50px;
      margin-top:150px;
    a {
      color:black;
    .tablecell2 {
      width: 160px;
      vertical-align:top;
      padding-top:30px;
  </style>
</head>
<body>
  <table class="table">
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
          <br><br>
        </p>
      </td>
      </td>
    </tr>
  </table>
</body>
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9891010
7 hours ago, zwirek2201 said:
Hi!
<head>
  <style>
    body {
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image {
      position: relative;
      display: block;
    .table {
      width:960px;
      margin: 0 auto;
      border-spacing:0px;
    .text {
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position:relative;
    .h2 {
      color: black;
      text-align:left;
      font-size:20px;
      margin:5px;
    h1 {
      color:yellow;
      margin-left:20px;
      vertical-align:top;
      font-size:50px;
      margin-top:150px;
    a {
      color:black;
    .tablecell2 {
      width: 160px;
      vertical-align:top;
      padding-top:30px;
  </style>
</head>
<body>
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
          <br><br>
        </p>
      </td>
      </td>
    </tr>
  </table>
</body>
thanks alot ! :)
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9892681
On 26.5.2017 at 9:43 PM, bomberblyat said:
thanks alot ! :)
<head>
  <style>
    body {
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image {
      position: relative;
      display: block;
    .table {
      width:960px;
      margin: 0 auto;
      border-spacing:0px;
    .text {
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position:relative;
	  float:left;
	  margin-left: 150px
    .h2 {
      color: black;
      text-align:left;
      font-size:20px;
      margin:5px;
    h1 {
      color:yellow;
      margin-left:20px;
      vertical-align:top;
      font-size:50px;
      margin-top:150px;
    a {
      color:black;
    .tablecell2 {
      width: 160px;
      vertical-align:top;
      padding-top:85px;
	  float: right;
	  margin-right:24px;
	.footer {
  position: absolute;
  right: 00;
  bottom: 180;
  left: 113;
  height:10px;
  margin-left: 130px;
  margin-right: 117px;
h4 {
	color: white;
	 vertical-align:top;
	 background-color: grey
a:visited {
    color: red;
a:link {
    color: green;
  </style>
</head>
<body>
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
          <br><br>
        </p>
      </td>
     </td>
        <li><a href="Etusivu.html"><h2 class="h2">Etusivu</h2></a></li>
        <li><a href="kokojasijainti.html"><h2 class="h2">Koko ja sijainti</h2></a></li>
        <li><a href="ihminen.html"><h2 class="h2">Planeetat</h2></a></li>
        <li><a href="palaute.html"><h2 class="h2">Historia</h2></a></li>
      </td>
    </tr>
	<th class="footer"><h4 class="h4">Site name</th>
	</tr>
  </table>
</body>
1 thing need to do anymore link visited styling to links and no clue how that happens ( if you wonder why there is <li> i heard you need that to style links)
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9899675
On 26.5.2017 at 2:24 PM, zwirek2201 said:
Hi!
<head>
  <style>
    body {
      text-align:center;
    .header {
      position: relative;
      text-align: center;
      margin-left: 200px;
    .image {
      position: relative;
      display: block;
    .table {
      width:960px;
      margin: 0 auto;
      border-spacing:0px;
    .text {
      position: absolute;
      top: 0; right: 0;
      bottom: 0; left: 0;
      text-align: center;
    .text h2 {
      color: yellow;
    .p {
      color: black;
      text-align:left;
      margin-left:5px;
      margin-right:5px;
    .tablecell {
      position:relative;
    .h2 {
      color: black;
      text-align:left;
      font-size:20px;
      margin:5px;
    h1 {
      color:yellow;
      margin-left:20px;
      vertical-align:top;
      font-size:50px;
      margin-top:150px;
    a {
      color:black;
    .tablecell2 {
      width: 160px;
      vertical-align:top;
      padding-top:30px;
  </style>
</head>
<body>
    <tr>
    </tr>
    <tr>
      <td>
          <div class="image">
            <div class="text">
            </div>
          </div>
        </div>
      </td>
    </tr>
    <tr>
          <br><br>
        </p>
      </td>
      </td>
    </tr>
  </table>
</body>
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9900293
You don't need <li> to style links. <li> tag is a "List Item" tag and it has nothing to do with links.
To style a link in CSS, you use selector "a" like this:
a {
  color:black;
In addition, links can be styled differently depending on what state they are in.
The four links states are:
  • a:link (or just a) - a normal, unvisited link
  • a:visited - a link the user has visited
  • a:hover - a link when the user mouses over it
  • a:active - a link the moment it is clicked
To style for more than one state, you have to use more than one selector like so:
a:link {
  color:black;
a:visited {
  color:red;
a:hover {
  color:green;
a:active {
  color:yellow;
I this example an unvisited link is going to be black and visited link is going to be red. When you hover over a link, it is going to turn green and while it's active (while you click it) it's going to be yellow.
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9900534
a {
  color:black;
a:link {
  color:black;
a:visited {
  color:red;
a:hover {
  color:green;
a:active {
  color:yellow;
ok thanks ill try it when i get to home ^^
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9900547
a {
  color:black;
a:link {
  color:black;
a:visited {
  color:red;
a:hover {
  color:green;
a:active {
  color:yellow;
sadly i didnt get it working i tried to google examples but i didnt find
https://linustechtips.com/topic/783512-csshtml-help/page/2/#findComment-9904390
