fans for inwin 303 case
ickyvicky125
hey yall,
I'm getting the inwin 303 case. I'm a rookie when it comes to static pressure vs air flow fans. I know the differences from watching videos all I want to know is which is best for that case? I want to get fans that are also rgb. if you have that case, would love to see what it looks like !! :D thank you in advance! =)
27 minutes ago, ickyvicky125 said:
hey yall,
Statcic pressure is for radiators and heat sinks. Get airflow fans. Thermaltake riing or the corsair and nzxt competitors
I use all SP fans with high air cfm, best way to do it (btw for basic case fans it doesn't matter that much whether AF or SP focused)
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
