maybe a spam prevention tactic
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822040
That's not something they can probably just fix. It depends on where you wrote the original piece on. If it's something like Word... Yeah, good luck preserving that.
There's kind of a rule in software development: always develop on your target platform as much as possible or something that is a very good substitute. The reason being if you develop on another platform, you can't expect everything to work as you want.
The same goes for something like this. If you need to save your work or something for this forum, there's a scratchpad forum on the bottom of the listing that only you (and the mods) have visible access to.
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822046
What do you mean by spacing?  Line spacing?  What are you using to write them?  Did you remember to clear formatting when you paste?
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822052
I use TextWrangler, but that's not the problem, I tried different programs.
Yes, Line spacing and here is a little example what happens:
Original Message (written somewhere else)
I am trying to copy paste
on the LTT forum.
After copy+paste
i am trying to copy paste this message on the LTT forum!
As you can see, it's one line.
Ofcourse this might now be a problem for my example, but when you're copy pasting huge posts it's annoying.
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822068
In HTML only the first space character has a fixed width. If there's multiple space characters one after another, the width doesn't multiply by the number of space characters, the browser isn't even required to treat them as multiple spaces.
If you want to have a fixed width space, you use the html code    which is short for "non-breaking space" which explains the true purpose of this code: if you use a single   between two words, the browser is not allowed to split a long sentence between those words (useful when wrapping long paragraphs in a page with dynamic width)
So basically, what you could do would be to paste the code in Notepad, then do a search and replace for two spaces and replace with one space and   and hope that when you paste the new text, the code behind the form will accept the   sequence and not replace it with regular space character.
An alternative would be to use a mono-spaced font where each character has the same width and maybe use html tags like  <pre>  </pre> which means anything between these tags won't be formatted by the browser in any way, it means the text is pre-formatted in some way. But again, the code on the website will most likely filter the tags and may remove the pre tags.
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822070
Well, it doesn't matter where I write this.
I tried copy pasting it from TextWrangler to YT comment section to Eclipse, nothing worked.
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822078
on the LTT forum.
After copy+paste
Oh interesting, I have never seen that happen.  You wouldn't happen to be using something other than Windows would you?
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822082
If you want to have a fixed width space, you use the html code &nbsp;  which is short for "non-breaking space" which explains the true purpose of this code: if you use a single &nbsp; between two words, the browser is not allowed to split a long sentence between those words (useful when wrapping long paragraphs in a page with dynamic width)
So basically, what you could would be to paste the code in Notepad, then do a search and replace for two spaces and replace with space and &nbsp; and hope that when you paste the new text, the code behind the form will accept the &nbsp; sequence and not replace it with regular space character.
Interesting, I'll try this for now, thank you!
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822093
I am using Mac right now but I used multiple programs and even word...
I wonder if there's a chance this is due to the Unix line ending vs Windows line ending differences... (you'll know what I mean if you've ever opened a text file made on mac or Linux with Windows)
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822111
btw, I'm going to move this topic into the Bugs section in case it is an issue with the forum, and that way it will also get some notice from our expert @colonel_mortis:)
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822122
Maybe.. Could you try it on this comment section? (you dont have to post the comment, just paste it in the bar)
Try and copy paste this:
copy paste
test
If it comes out like "copy paste test" it's universal, otherwise only mac I think
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822124
Does that mean the line breaks are stripped out when you paste into YT/Eclipse too? That sounds very much out of our control.
Line breaks aren't removed for me running Firefox on Linux, copying from LibreOffice and Terminal (and every program that I've ever used it on before, they are just the ones that I verified it with just now).
HTTP/2 203
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822307
No, just when I paste on LTT forums.
When I paste it anywhere it's fine, but here it's broken
edit: I use macOS and Chrome
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822453
If you copy and paste this post,
  • Does it keep the line breaks?
  • Is the formatting (bullet points, bold, colour, etc) retained?
  • Do you get a banner at the bottom of the editor asking you whether you want to remove the formatting?
    • If so, what happens if you click it?
Are the line breaks retained if you paste into the editor at http://ckeditor.com/features?
What about if you click into this box, and paste there?
(you'll need to do that in my post rather than in the version that you copy into the editor).
HTTP/2 203
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822488
Paste here!
Interesting,
I can copy and paste your messages with no problem.
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822540
10 minutes ago, ZUB xD said:
Interesting,
Which of the bullet points are met if you paste something else, where the line breaks do get broken, into the editor (and into the ckeditor link and into the editor box that I included in the post)? Microsoft word is a good test because there is formatting that you can test with, but I am also interested in the behaviour when there is no formatting, just line breaks.
(Please refresh the page if you loaded this post inline, because I have modified my inline editor).
HTTP/2 203
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822606
I copy pasted your bullet points on CKEditor, it worked fine.
But back to the original problem, I still can't copy paste anything from anywhere.
About the CKEditor thingy, I have no idea what you wanted me to do? It works fine on there but just not on the forum (for me).
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822687
If I understand you correctly:
  • Copying from the forum to the editor on the forum works as expected, with line breaks and formatting retained
  • Copying from the forum to http://ckeditor.com/features works as expected, with line breaks and formatting retained
  • You haven't tried copying from the forum to the box in my post above
  • Copying from an external program to the forum removes line breaks (but you haven't tested it with formatted content, such as from Microsoft Word)
  • Copying from an external program to http://ckeditor.com/features works as expected, with line breaks and formatting retained (this is important, please make sure this is right!)
  • You haven't tried copying from an external program to the box in my post above.
Can you test the cases that you haven't already, and correct me on anything that I have misunderstood.
Also, what browser are you using?
HTTP/2 203
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9822716
Yes
Yes
I have tried copying to your box above, worked fine.
Indeed
That is right.
I have, it worked fine.
I am using Google Chrome.
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9824654
1 hour ago, ZUB xD said:
Yes
Yes
Indeed
That is right.
I can't reproduce this. In my MacOS Sierra VM, line breaks are retained when copying from TextWrangler 5.5.2 to Chrome 58.
HTTP/2 203
https://linustechtips.com/topic/778822-spacing-using-copy-paste/#findComment-9824774
