CPU Temps
34 minutes ago, awebos said:Hi Guys!
Following your advice, I went for upgrading my PSU & CPU instead of getting an overkill GPU. Now, I made an error when running the numbers and ended up with a $300+ CPU and a $30 cooler (7700k & 212 EVO). I made a custom fan curve that goes like this:
- 40% at 30°- 60% at 50°
-100% at 70°
I haven't overclocked just yet and when running Aida64, the max temp I got was 71°. However, would you consider that the fan curve might be optimized? Does anyone with a similar setup has similar temps?
Also, what would be a good upgrade when it comes to cooling the CPU? Would you rather go with air or AIOS?
Thanks in advance for your help, have a great day!
It's fine as it is, real world situations would be unlikely to run that load, so should be cooler than that during gaming for example. I wouldn't change anything TBH, 71C isn't a bad temp at all for stress test.. but if you're going to OC you might want to look at an AIO or a better air cooler.
