guys i was just going through pc parts picker i thought lets make a build as completed build then i saw there is no option to mark it as completed and i saw many builds as completed so can you guys tell me how to make a build as completed build
My personal Build as i am a cool tech enthusiast B|
https://pcpartpicker.com/user/TheSneakyRM/saved/
https://linustechtips.com/topic/777886-pc-parts-picker/
your motherboard has 4 dimm slots. I recommend using 2 for your ram. get a 16 gb kit of 2 8 gb sticks for better performance and more ram. If you need more, get that same kit and fill up the remaining 2 dimm slots (ram slots.) Make sure you fill up the 2nd and 4th dimm slot from the cpu first. They are optimized for a 2 way ram configuration.
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9811124
18 minutes ago, killer5247 said:
there is no such option send screenshot by marking it
Looking for it now. I'll post it in a minute...
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824408
Ok, so while on the home page, click "See all completed Builds" at the top. Then there will be a blue button that says "Create a completed build". Then just pick your part list and add a Title, description, and photos.
Cheers!!
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824419
Cheers!!
where it is i cant see that plz screenshot it
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824427
Which button don't you see?
(Also make sure you're logged in)
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824431
yes i am logged in i dont see the create a completed build one
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824432
This Blue button...
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824451
see it is not there
Mark all of the parts in your build list as purchased. Might change it.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824463
23 minutes ago, killer5247 said:
@Brink2Three any else thing
I really don't know why it's not showing up then...
Sry dude. Keep poking around. Maybe you will find it.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824574
At this point you may want to be in direct contact with PCPP support. Its their site so they can do more further troubleshooting than us.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824632
Please, be more patient when it comes to replies. There aren't people online 24/7 to help with you issue here, and waiting a day will net you a much better response than pestering for a reply every 5 minutes.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/777886-pc-parts-picker/#findComment-9824784
