Refueling while an engine is running.
Go to solution Solved by Zyndo,
4 minutes ago, Okjoek said:
I've always wondered if doing this is actually dangerous. I would never try it with an automobile, but I regularly do this with the lawnmower and snowblower because one time the lawnmower's battery was dead and I didn't feel like jump starting it again and the snowblower because a snowed-in driveway (ours is very long) is much more serious a problem and to start it I either need an extention cord or I have to use the dreaded pull cord ignition.
I'm just curious because I was under the impression that causing a disaster in this way is highly improbable.
filling up an internal combustion engine with, combustible fuel, while its running is 99.999999999% of the time safe (you can throw on a whole lot more 9's to that if you want). However, it DOES open up yourself to a potential danger which has very severe repercussions. so if you do it, odds are incredibly high that nothing bad will happen.... but if something bad DOES happen, something very very bad is going to happen... so why not just turn off your engine? not like it has to stay running or anything lol. the problem becomes especially horrible if one of these fires starts at a gas station.
I mean if you were filling up your lawn mower with a jerry can while it was running and it caught fire..... you would have a small fire, maybe scare you a bit, burn some of your grass, and absolute worst case scenario MAYBE burn your house down if you had enough fuel in the can and you didn't react correctly to the fire. take that same scenario to a gas station and you're looking at an uncontrollable fire which burns for hours and has the risk of exploding and killing a great many people in addition to the massive amount of property damage.
So its not that filling up a tank while its running is inherently dangerous or anything, but why open yourself up to the risk when its so easy to avoid and the results can be so disastrous?
1 minute ago, AnonymousGuy said:
Wouldn't surprise me if the "turn engine off" is a carryover from the days of distributors where there actually was a spark in the engine bay, and is irrelevant nowadays.
engines still spark all the time (incredibly frequently actually). sparkplugs are responsible for the sparks which ignite the fuel and drive the engine... your car wouldn't work without sparks. they're definitely still there.
https://linustechtips.com/topic/775775-refueling-while-an-engine-is-running/
I do it every time with my car.  So does my friend.  No issues.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
My dad did it all the time with his vehicles. No problems. Should this be in Off Topic?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
One spark and you could have a disaster. When I used to drive long haul semi's, watched a lady refill her car fuel tank while the engine was running. 10 seconds in and she answers her phone.  Poor...instant fireball at the pump
I'd avoid it at all costs.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
I thought mythbusters busted the cellphone myth, but maybe the car running wasnt a factor, idr.
They did.  It's probably something that *can* happen as a 1:100000 chance, but so can getting hit by a meteor or dying in a car crash on the awy to a gas station.
Wouldn't ever even try, although I can't even do it since I need my keys to open the cap...
My stuff:
CPU :  Intel i5 8400 | GPU : MSI GTX 970 Gaming 4GB
RAM : 32GB Corsair Vengeance DDR4 @ 3600MHz
Mouse : Logitech G502 HERO SE | Keyboard : Mountain Everest Max w/ Cherry MX Brown
Headset : Beyerdynamics DT990 Pro 250Ω w/ AT2020USB+
Monitor : Acer XF240H @  144Hz
-Thread moved to Off Topic.
This should be a thing on every car.
USEFUL LINKS:
PSU Tier List F@H stats
All it takes is something with a hot enough surface or exhaust coming from the tail pipe for the fumes to go up in flames. The ignition point of gasoline is 247–280 °C (477–536 °F) at one atmosphere of pressure. If a small invisible flame shoots out the tailpipe it'll do.
Kind of depends on the situation, but in general it's best not to. On something like a motorcycle where the fuel tank is above the engine and electrical are all close by, it's really not a good idea as a little spill of fuel could catch fire if it hits the wrong spot. Really, you shouldn't even have the ignition on as if there's exposed wire with current flowing through it, a tiny spark from that could catch the fuel on fire.
I can't see any reason to leave the engine running when refuelling, it's not like it's going to save you much/any time. I also think it may actually be illegal to refuel with the engine running here in the UK (at a refuelling station, you can do what you want at home and such)
EDIT: Obviously starting issues could be a reason to leave the engine running, but really you should try to fix the issue before using the vehicle anyway.
In my instance with a snowblower/lawnmower I'd turn the machine off and turn the fuel flow knobs to the closed position and try to smother the flames with snow, or my shoes/shirt in the case of the lawnmower. Unlike a gas station the only fuel that's not in the machine is in a little red can that's got a shutoff when this cylinder surrounding the outflow isn't pushed down.
This is pretty close to what it looks like:
If it were up to me though we'd have switched to all electric equipment though. I just feel that it's a more versatile fuel source in that you can make it yourself in many ways including by gasoline whereas in an emergency like a fuel crisis or massive power outage I can't just make my own petrol.
Edit: by "we" I mean my household, sorry
2 things:
Someone always wins the lottery
What do you think happens in your wiring harnesses and electronic sensors, wiper relays, wiper motors, etc?  Current flow, which causes sparks.
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
The reason you aren't supposed to fuel while your car is running is because there is a brushed electric motor submerged in gasoline. Every time the brush crosses over a commutator bar it can create a powerful arc. Your tank has a venting system where when you are filling up, the fuel you are pumping in pushes out the fuel vapors into whats called a charcoal canister which is a part of the EVAP system. It also recirculates some vapors near the top of the nozzle. What can happen is while you are pumping, air can be forced into the tank through a venturi effect at the nozzle. When your tank has air introduced into it can become volatile with the fuel pump.
In Washington it is illegal to fuel a car while running. There are also other risks, but thats more involves improper pumping methods, like going past the first shutoff click at the pump. You can force fuel into your charcoal canister, which is made easier by having the engine running while fueling because there can be a vacuum on it from the purge valve being open. If you really keep forcing fuel into there it can stall your car and prevent it from being started due to flooding the engine out.
5800X3D / ASUS X570 Dark Hero / 64GB 3600mhz / EVGA RTX 3090ti FTW3 Ultra / Dell S3422DWG / Razer Deathstalker v2 / Razer Basilisk v3 Pro / Sennheiser HD 600
2021 Razer Blade 14 3070 / iPhone 15 Pro Max
The pump manufacturers take the Stupid Factor into consideration, as there are many stupid fucks out there in the world. But it would be generally safe but it is not recommended, neither is smoking while refueling.
Heck I even leave my truck running when I see stupid little signs that tell me what to do "Please Turn Off Engine" or "Air Intake - Turn off Engine" and I say fuck that, I either want my a/c running or my heat running. Its fucking stupid what property owners want you to do.
