It's more CPU bound especially at that resolution. You have 124 frames anyway, so it doesn't matter much.
https://linustechtips.com/topic/774755-low-gpu-usage/#findComment-9773724
8 minutes ago, saritacute said:
will i still maintain my fps even if I go to a higher res.?
Maybe will drop a few FPS if you only change the resolution and don't change the video settings
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/774755-low-gpu-usage/#findComment-9773761
Probbably because of the FPS cap.
Change resolution to 1920x1080 and see what FPS and CPU/GPU usage you get.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/774755-low-gpu-usage/#findComment-9773778
Happens to me in certain games, its usually because your CPU is limited. For instance my GPU in fallout 4 and PUBG only goes to 99% sometimes, then it fluctuates from anywhere between 1-99% randomly, while that's happening, my cpu is exploding at 80+% usage. Open worlds are not nice to quad cores.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/774755-low-gpu-usage/#findComment-9773792
my gpu never reached 65%, never
https://linustechtips.com/topic/774755-low-gpu-usage/#findComment-9773801
I'm sure you can up the resolution, no problem.  Try upping it to 1980x1080 and tell give us the results you get there, that will be helpful.  And, the other members are right.  120 fps is good enough.  It could be a CPU bottleneck or frame capping depending on the CPU usage.
https://linustechtips.com/topic/774755-low-gpu-usage/#findComment-9773886
