Very good PSU, will work well.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773002
The G3 (at least the higher-wattage models) is the best performing power supply on the market, but it also has a loud fan. Up to you how much of a tradeoff you're willing to make. If you're annoyed by fan noise the G2 or Corsair RMx's would be quieter and similarly priced alternatives.
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773005
That's an excellent one.  I have  the G2 which was extremely well reviewed, and the G3 that you've linked is just an even higher end version.
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773008
I don't really care much about how loud it is, what I would like is for the bearing to not go bad within like 2 years and make this awful grinding noise
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773010
Why not disassemble your current PSU and replace the fan?
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773015
Just now, Dodgeyou said:
I don't really care much about how loud it is, what I would like is for the bearing to not go back within like 2 years and make this awful grinding noise
It's an HDB fan, so it shouldn't be going bad anytime soon. 10 year warranty should also cover that sort of thing.
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773016
17 minutes ago, Dodgeyou said:
So I wanna get a new PSU after my Corsair CX600M's fan started to really drive me crazy as it has already worn out as most people with this PSU can say, so I wanted thoughts on the PSU I wanna get next
https://www.newegg.com/Product/Product.aspx?Item=N82E16817438095
Its a good psu like said above by several, my go to is the SeaSonic brand.
You can oil those fans after a time, the bearing is a sleeve bearing I believe. Pull off the sticker and put a drop of oil on the bearing.
That or replace the fan if the PSU itself is still good.
Image result for 3 in 1 oil
 CHRISTIAN MEMBER
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773020
Good PSU
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773207
1 hour ago, Jrock said:
The evga supernova PSU's are very good.
*Some EVGA Supernova PSUs are very good, while other are okay or not amazing.
G3, G2, P2, PS, 1000G, T2 are very good.
B2, GS, GQ are quite good
NEX-G is average
NEX-B is not completely awful, but not good.
B3 is unknown but likely quite good.
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9773257
Expect for the mediocre NEX units
Best performing, no. Loud fan, yes.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9778869
On 5/3/2017 at 9:43 AM, Dodgeyou said:
I've used many Corsair PSUs and have never had a good one, i'm just gonna move on
You can't judge a brand like that. Corsair has many excellent PSUs, yet it also has many bad PSUs
Desktop specs:
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9778873
What are the best-performing PSU's in your mind? AX1500i and Seasonic Prime Titanium? 1600 T2?
Take a look at the 12V ripple and transients on those vs the 1000W G3. Only the 1600 T2 is trading punches, and that's mostly because of the advantages of being larger. Granted, they're all so high-performing that real-world effects will be practically nonexistent.
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9778992
Well, you're saying best performing PSU on the market so AXi and Prime Titanium are one of them
Instead, I would say that EVGA G3 is one of the best performance TO PRICE PSU.
Desktop specs:
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9779004
The G3 has better 12V transients and ripple than either of those. Just because it's cheaper doesn't mean it performs worse.
https://linustechtips.com/topic/774692-thoughts-on-power-supply/#findComment-9779126
