1080ti FE or aftermarket for watercooling
Solved by PCGuy_5960,
Just now, Ardox said:The 1080ti Strix OC is 7500 danish crowns and the MSI founders is on offer for about 5500 right now so roughly 2000 kr. difference and that is equivalent to 293,88 US dollars as of right now I take it as the majority (all of you) recommend me to get the FE and save the dollars?
Yeah, I meant that it is 100% not worth it. It won't OC better and since you are watercooling, the crap FE cooler is not a deal-breaker
Definitely get the FE card
