Hi ,
So technically my fan died! (Noisy sound and barley spinning which is bad for me. ?)
Okay here's my question :
can i change the power supply fan with the case fan?
Reason asking this question: i broke. ?
Thanks for your time ( and please help don't read and leave ? )
Just a Boring Web Developer that never learns from his mistakes.
https://linustechtips.com/topic/771064-changing-the-powersupply-fan/
Depends on the power supply and it will also void you warranty.
Have you tried RMAing it?
3 minutes ago, Devel0per95 said:
Hi ,
It's dangerous. Must have advanced skills. There are chance you electrocute yourself. Plus 95% of the time it's not worth it.
Just buy a new PSU
Just buy a new PSU
Just don't touch the board and your fine, its not really dangerous.
Ok so the really simple solution is if your PSU is on warranty still, contact the manufacturer and they'll replace / repair it for you.
If it's out of warranty, there's this.
It's not terribly hard but depending on the fan that's inside your PSU you might have to take a soldering iron to it. And please if you care about your own safety, leave the PSU disconnected the night before you open it. This is important so that the capacitors inside discharge during the night and don't give you a potentially harmful shock if you touch them. Either way I recommend working with care not to touch any component on the inside.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
6 minutes ago, Electronics Wizardy said:
can't void your warrantly in the US legally.
You can use any case fan.
Yeah it will, when you cut and solder the wires to attach a new fan which is in no way meant to go in there.
Also no, you cannot use just any case fan.
It needs to be the correct diameter to screw it in, and it needs to be the same type as the fan in the PSU.
A PSU that runs a PWM fan will not work with a 3 pin fan.
You could fry yourself so... If it's a high end one, it's probs under warranty still and they'll fix it. If it's not a high end one, it's most likely easier and cheaper to buy a new one (your brain being fried is an expensive impossible thing to fix).
Although I'd still try it just for kicks. I've been dissecting electronics since I was a kid :ph34r:
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
8 minutes ago, smokefest said:
Even broke I would prefer to try to streal one instead of repairing one. Less dangerous for your life loll depending on what country you live xD
oh well, i've done it a couple of times and i am still alive.
but that's just me and i guess i should not recommend doing it yourself because it really CAN KILL you.
opening a power supply should be the LAST option to consider. if at all.
can you RMA your current PSU ? if you can, do it.
if not - do you have another PC around you can borrow the PSU from until you have money to buy a new one ?
Okay here's what happened i found  powersupply but with no sata plugs then i have found 1 small sata plug and the problem i have 2 hard driver , i plugged it in the main system hard drive and now getting this, d checked the bios options its plugged in!
What PSU's are you using/ how old are they?
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
No need to solder there are connectors.
For size a yea not needs to be the same size for connectors you can easily change the plug housing
For warranty even if you soldered your own fan it wouldn't void your warranty as third party repairs are covered under the law.
1) The connectors inside a PSU are not regular fan headers like on a motherboard
2) no you cannot change the plug housing, the pins are not the same
3) Unless you file a lawsuit (which will cost you tens of thousands of dollars) the PSU manufacturer will refuse to give you a new PSU if you have modified it.
