Fan splitter amp math check
Go to solution Solved by Enderman,
2-3 fans per header is the max recommended, so yeah it will be fine.
According to the manual of my motherboard the CPU fan can take a maximum of 1A. I can't find something about the chassis fan connectors, but I'm assuming this is the same. For my setup I'll be using two Nidec Gentle Typhoons (rated at 12V/0.083A, and 0.44A peak current according to the store) and three Corsair SP120 RGBs (included with the case, rated at 12V/0.30A).
Since I don't have enough headers to connect all of these fans to the motherboard, is it safe to use a splitter?
I'm thinking 2x0.083A = 0.166A (or 2x0.44A = 0.88A peak) on one header and 3x0.30A = 0.9A on the other should technically be fine, but I'd like to be sure before frying anything :)
[Edit] My motherboard is the Asus ROG Strix Z270F Gaming
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/769633-fan-splitter-amp-math-check/
Perfect. Thanks :)
Does that extend to 140mm fans? I've got two 120mm fans that draw 0.17 amps and a 140mm fan that draws 0.32
I've read that fan headers on modern boards from more reputable manufacturers are often good for up to 1 amp but I'm concerned there might be a spike when they're first turned on that might eventually burn out my header.
Not sure if 2-3 fans is just for 120mm as they are quite a bit more power efficient than 140mm, and/or if it takes into account a spike and/or resistance in the motor at start-up.
Advice would be most appreciated.
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
(actually might just start a new thread)
The math works out so If it's ok in my case you should be fine as well I'd say.
