Any advice for someone thats new to custom water cooling?
4 minutes ago, OnlyStealth said:I'm not planning on cooling any graphics cards i use 3 1080p ultrawides so i dont feel like i need anything higher than a 1070 and i dont feel it needs to be oc and temperatures in the uk are always low. This is mainly for aesthetics due to there not being any white AIO coolers.
This is a perfect response.
For anyone going into custom water cooling, the question of "benefits" should really be secondary.
If your reasons for wanting to build a custom loop can't be boiled down to "because I can" and "I want to" then you're not in it for the right reasons.
If you're looking for white radiators, I would suggest looking at what Hardware Labs has to offer.
That's what I use in my rig now. Good quality radiators too.
I don't think you'll find any kits with these so be ready to do a little research and prepare to go fully custom if you don't find a kit with the colors you're looking for.
