Which CPU Cooler should I use between Corsair H60 & CM Hyper 212X Turbo (dual fan)?
This is my first post here after lurking for a long time so hopefully, I'm doing this right... but here's my situation: I have both of these CPU coolers already (can't return them) so money aside I was wondering which one would give me the best CPU temperatures for my I7-6700K? I also have on hand a spare Corsair Air Series AF120 Quiet Edition 120 mm fan that I can use with the H60 if necessary. I've seen a couple of posts/threads say that the CM Hyper 212 is better, but the reasoning behind it was partly due to the H60 being ~$20-30 more expensive. This is my current build (accumulated over the years): Triage's Build . Thanks!
I know this is alot more the price, but before deciding to buy those, think about buying a: kraken x62
1 minute ago, Pewdiepies Pie said:
I know this is alot more the price, but before deciding to buy those, think about saving up for this... https://www.amazon.co.uk/NZXT-RL-KRX62-01-Kraken-Liquid-Cooler/dp/B01M191GRY?th=1&psc=1
OP Already has both coolers.
Id go with the 212, they should perform about the same.The benefit of the h60 is just noise afaik
I'd go with H60
The H60 will be a bit better. Won't be the most amazing temps you could ever imagine but it'll do a better job. It may be louder at idle because of the pump.
And since you already own both coolers, why not test both and see which you like best :D
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Thanks for the fast responses guys! Yeah, I think I'll test them both out. I might sub out the fan that the H60 came with to the Corsair Air Series one. I had the 212X in my old build, and the H60 was used on my gf's computer (which she isn't using anymore). I think I might also test using a push-pull configuration for the H60. I know it's ideal to have two fans of the same type, but would using 1x Corsair Air Series AF120 & 1x the H60 Stock Fan work or should I try using the two fans that came with the CM Hyper 212X Turbo instead (or any combination of those fans)? Thanks again :)
5 hours ago, Triage said:
This is great! Very informative. Thank you :)
Actually those graphs are pretty awful to make true comparisons. The test systems are obviously different and there aren't any coolers to use as baseline.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
both have received good reviews but It should be what you want like how quiet i would test both for like 1 week and see how each does then decide also really nice build.
Ex frequent user here, still check in here occasionally. I stopped being a weeb in 2018 lol
For a reply please quote or  @Eduard the weeb me :D
Xayah Main in Lol, trying to learn Drums and guitar. Know how to film do photography, can do basic video editing
