Help with videocard on editing pc
Solved by crzyces,
The 1070 will make a big difference in both as it will take more of the stress of your cpu. Why the cuda booster is enabled in 1070 and above I do not know, but it is, so in both Adobe and Autocad you will see acceleration (Not to a Quadro or Pro Dou (yes I know the pro duo does not use cuda, but Opencl which they developed and let NVidea use on the cheap) level, but it's there, where as in the 1060 it isn't). The gaming benefits are blatantly obvious, and for a $339 card, it's only $60 or so more than a 6 gig 1060.
