Scan it, use photoshop to touch it up without any inside colours, print, cut, boom, you have a template.
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
Do you have any idea what i can use to cut out from? If i use paper the final product wont be really neat
See you around
Karl Out
Now that seems familiar...
Angels and demons?
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
What can i use for a stencil?
you could thick paper, cut it neatly, and tape it stuck properly.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
Cardboard or Cardstock?
Thank you, ill probably try some thick paper or something. It seems a bit skcetcy, but it will probably work just fine.
Print it out on thick construction paper and use an xacto knife to cut out the template.
Paper works, but carton is a lot better.
No idea actually, my brain says that something thin and easy to cut. Thin cardboard or paper?
See you around
Karl Out
I'll give my 2 cents. The methods I have used in the past to do patterns like this is get a sheet of wax paper or a glass coffee table you don't mind accidentally scratching. Then get some 30 day masking tape and cut long enough strips to do the width of your pattern and overlay other strips to the height you need(the edges of the tape strips need to overlap to make 1 big sheet). Then trace out your pattern using a thin sharpie marker\pen and cut out you pattern with a very sharp knife. Now you will have a sticky stencil just be careful peeling it off the wax paper or glass surface so that the individual strips of tape don't come apart. It takes practice to do but you can get some great looking sharp results.
When i previously have made larger "images" on remote controlled car bodies. I've bought A4'ish sized masking paper. Which you can print out on and cut it. When using cardboard or paper, there WILL be some paint than find it's way under and mess it all up.
If you have a hobby store near you, you can ask them after "Parma Uncut Vinyl Masking Sheet #10799"
As I see you're in Norway, so if the store got stuff from "Minicars.se" (only scandinavian traxxas importer) they should be able to get it.
Or towerhobbies got them at 4,89 pr sheet.
