It depends on what model the power supply is, a very bad one which I believe it could be since all power supplies these days have automatic voltage switchers and I don't know this brand at all then there's the possibility it damaged other components... you can throw the power supply unit on the garbage already since it's dead for good but you'll only know about the components when you power them up using another one.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/762364-wrong-psu-voltage/#findComment-9633497
2 minutes ago, RaiSiegfried said:
i accidentally switched my psu's volt to 115v and plugged it to a 220v socket, it sparks but does that mean it killed my entire rig?...or will my pc gonna run if i switch it back to 230v?. The psu is Huntkey 450w 80+ need fast response thanks in advance.
Common sense would dictate to get another power supply and test the system with that before considering using that power supply again.
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/762364-wrong-psu-voltage/#findComment-9633501
