Best way to get a cable from inside to outside the case
Solved by Davidwr80,
there are litte metal pieces at the rear of your case. You can punch them out to pass cables through
Featured Topics
tippytipper ·
Posted in Storage Devices1 -
2
AlyShazli ·
Posted in New Builds and Planning11 -
4
Emmanuel Katto ·
Posted in Peripherals3 -
3
2
Rusty Proto ·
5
WildOne ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
